Beta High Intake Cam
Old Oct 5, 2001 | 01:06 PM
Elantra151's Avatar
Default Beta High Intake Cam
is saw this advertised somewhere where do i find information.whats the web adress?
Old Oct 5, 2001 | 03:42 PM
dj_dlrm's Avatar
well if you have the 2 litre beta you can swap it with the 1.8 litre beta cam witch is higher then teh stock semi high cam.
they are fairly cheap and can be bought through your dealer or possably shark racing.
Old Oct 5, 2001 | 08:26 PM
It is only the 1.8L Elantra (96-99) cam The 1.8L tiburon cam is the same as the 2.0L
It is the intake cam only. Exhaust cams are all the same in all betas.
The new 2001 Elantra intake cam is even better, but folks...keep in mind, you are talking about maybe...maybe 3 HP for this mod.
The 1.8L Elantra cam has only .4mm more lift and 2 degrees more duration
The 2001 2.0L Elantra cam has only .8mm more lift and 4 degrees more duration.
If you want more power...performance camshafts are the way to go...not stock cams from other motors. We are talking about very small changes...the stock valve lift is 9mm. adding an additonal .4 or .8 isn't going to make that much of a change. and 4 degrees of duration is not much either. Neither cam will show a gain untill above 4000 RPM, and even then...only about 1-4 HP to the wheels.
Performance cams should be good for 5-15 HP to the wheels. When you consider the cost of the cams...and the cost of installing them (or your time if you do it yourself), you might as well get some REAL performance cams for your Money/time.
Old Oct 6, 2001 | 12:00 AM
QuikTib's Avatar
Random, how much are these performance cams? and how hard is the install? Do you have to replace other stock components like springs and such?
Old Oct 6, 2001 | 01:19 AM
2K3GT/2K Wagon's Avatar
Also Random where can these performance cams be purchased?
Old Oct 6, 2001 | 05:47 AM
dj_dlrm's Avatar
thanks for clearing that up random anout the 1.8 cam. wouldnt want someoen to buy a 1.8 tib cam and it just be the smae one and a waste of money smile.gif
Old Oct 7, 2001 | 06:05 AM
The Performance cams can be purchased from HVE, RPW, HDK (shudder), and...hopefully when boogyman get us the specs...Shark Racing.
The Cam manufacturer can tell you if they should work with your stock springs, but 90% of them can, it takes a fairly agressive cam to require new Valve springs.
New stiffer Valve Springs are available from HVE and RPW.
Old Oct 7, 2001 | 01:13 PM
Elantra151's Avatar
alright i have heard that for the time money and the problems it can cause id rather spend the money on something that give more hpr. well random and others what would you spend your money on for better gains.excluding the obvious(blower/turbo)
Old Oct 8, 2001 | 12:51 AM
In order of things to do...
Cold Air Intake
Bored TB
Bored Intake Manifold
Headers
Full Exhaust
CAMS
Right after that you would probably benefit from an S-AFC to make all of the mods work together with and to fool the stock ecu into dumping more fuel when needed and lean things out where needed.
Then you get into the complicated things of port/polish work in the head, and either Nitrous or Turbo or Supercharger.
Old Oct 10, 2001 | 04:55 AM
Brendan's Avatar
I should point out the 1.8 cam really does work well, .4mm and 2 degrees may not sound like much but 2 hp to the wheels helps. The 2001 cam may help ,ore but wait a bit to see how hlas like it. Remember that the 1.8 cam is very MILD and if you run into trouble under warranty dealers will not notice it ( same with 2001 cam ) but the performance cams are a dead give away if you are under warranty. the duration and lift are not the only factoers in cams, the 1.8 cams gives a nice pull right off the line and 4500 rpm you actually do feel it . performance cams do more.
