Projection lights for my '99 elantra
Old Nov 7, 2002 | 01:25 PM
grind's Avatar
Vehicle: Hyundai Accent
Default Projection lights for my '99 elantra
The stock headlamps on my '99 elantra are getting cloudy and instead of buying the original replacement lamps I wanted to buy a set of projection lights, similar to those on the '98 tiburon.
First of all, I've never seen an elantra with projection lights ... are they available, and if so where can I get them ??
You can either send your replies here or to waynej@ppsl.co.tt
Thanks in advance.
Old Nov 7, 2002 | 01:43 PM
I don't know of any projecton headlamps available for your car.
If you order "korean" spec headlights, they should have a glass front, rather than a plastic front. They should not cloud over time like the plastic units do. I know you can get them through shark racing, and possibly HDK.
Plz keep in mind they will NOT be DOT legal, however, I've had my Korean Spec Tibby headlights for almost a year now, and no troubles with the law yet! (knock on wood)
Old Nov 7, 2002 | 02:14 PM
grind's Avatar
Thanks a lot Random, I'll check out those sites wink
Old Nov 7, 2002 | 09:38 PM
plantenutz's Avatar
Is their anyway of makeing the fog go away?Because my left headlight is pretty foggy and it shines alot dimmer then the right.Will the warrenty cover this or do i have to buy a new one?
Old Nov 14, 2002 | 02:40 AM
Type-H's Avatar
I too had a question about this subject. The guys on my job say that they can custom a pair of projectors for my Sonata, but my question is will they be better than my stock housings? I have a HID conversion and I want them to look just like the Beamers and Audis, but I know alot of Honda conversion projectors that are plain garbage as far as output and pattern goes. So should I spend my money on them or should I hold out for a Major comp.?
Old Nov 14, 2002 | 03:40 AM
SPIKE's Avatar
I can get KOREAN SPEC products..but lights esp. w/the HID lighting is expensive
send me an email: SPIKE@sharkmail.ws if U need any KOREAN spec items smile.gif
I may be able to help out
