Rundown on "The Plan".
Old Oct 25, 2001 | 12:39 PM
Thinking's Avatar
Default Rundown on "The Plan".
OK. I've mentioned before that I am planning on getting a 2K2 Elantra GT and having 8000 to blow on mods. Here's what I have come up with:
1: 205/40R17 Kuhmo Ecsta 712s $800
2: KAAZ, Clutch, Labor $2000
3: Alpine Turbo less UNICHIP $2000
4: Haltec E6K, Sensors, Install, Tuning $2000
5: 440cc Injectors, Fuel Pump $600
6: Custom Mandrel Bent 3" Exhaust w/Random Cat Con $600
7: Misc. crap that will finnish off the 8K and then some (plus whatever snags get in the way).
Anything I overlooked?
Old Oct 25, 2001 | 12:57 PM
skierd's Avatar
Vehicle: 1997 accent L
cut the price on those kuhmo's in half dude. They aren't 200 bux each, more like 100 in that size. Use the remaining $$$ to get some nice 17's.
Old Oct 25, 2001 | 01:09 PM
Thinking's Avatar
Sorry. That was wheels and tires together.
Old Oct 25, 2001 | 01:21 PM
Lt. Roasta Botch's Avatar
that's a long screen name
Old Oct 25, 2001 | 03:32 PM
BlueGT's Avatar
Vehicle: 2004 Tiburon GT
I think you should get 205/45 R17. Those will be closer in overall wheel diameter than 205/40 R17. Running smaller diameter will make your speedometer reading higher and your odometer will show higher mileage. Check www.c5-corvette.com/tirecalc.htm to compare the measurements. Also www.tirerack.com recommends 205/45 R17 for 2001-2002 Elantra.
[ October 25, 2001: Message edited by: BlueGT ]
Old Oct 25, 2001 | 03:41 PM
Iago's Avatar
What's your rationale behind recommending the super over the turbo for road / rally racing?
Old Oct 25, 2001 | 03:55 PM
Guilty's Avatar
Vehicle: Custom Wagon
I always thought if you were going to run a turbo/sc you should run 3" pipe. But for normal NA engines 21/4" to 21/2" was good. If your running a turbo/sc with 3" exhaust and if you do lose a little low end torque wouldn't recover after the turbo/sc spools up?
Old Oct 25, 2001 | 11:12 PM
Iago's Avatar
<div class='quotetop'>QUOTE </div><div class='quotemain'>Originally posted by guilty:
I always thought if you were going to run a turbo/sc you should run 3" pipe. But for normal NA engines 21/4" to 21/2" was good. If your running a turbo/sc with 3" exhaust and if you do lose a little low end torque wouldn't recover after the turbo/sc spools up?</div>
I think it depends on the size of the turbo and the level of boost you're running. If you've just got a tame 5 - 7 psi going, then you may not benefit from 3" pipes. But, if you're runnning Red or Onpol amounts of deathboost (15+psi), then you would do well with 3" pipes.
And, I don't believe you ever "catch up" to your low-end torque when your turbo spools up. That's kinda the problem...the turbo isn't spooling up until you're at a higher RPM, and thus outputting enough exhaust to spin the turbine. At that point, you are technically no longer in the low-end torque bracket, because you are no longer at your lowest RPM range.
Old Oct 26, 2001 | 02:38 AM
skierd's Avatar
I think 3" would be fine for forced induction, no matter the boost, because the turbo is a big enough restriction that a bigger pipe is no problem, to a point.
I would think a supercharger would be better for a rally car because of the power improvement throughout the rev range, not just above 3000+rpm (depending on tuning of course). Of course, every rally team out there seems to use a turbo (probably because of durability, i think the charger belt would snap on a lot of special stages).
