- Msd Racing Ignition
- Tuning Smt-6 Question
- Bbtb
- Acceleration Sensor
- Help...
- Type Of Spark Plugs
- First 3
- Reviving My Tib
- Airrams, Headers, Bbtb's And Other Na Mods
- Hood Noise/heat Shield
- Sponsorship Deals
- Low Temp Thermostat
- Octan Booster
- Turn Signals And Headlights
- Clear Corners
- Gauge Pod On Ebay
- Volt Meter
- Screen Removal
- Oil Pressure
- Exhaust....what To Purchase?
- Looking For A Cat Back
- Steering Wheel Problem..plz Help
- Cold Air Intake
- S-afc2 Wiring
- Cabin Filters
- Exhaust Cam
- 0-60
- Rd2 Shop Manuals
- New Tib Owner
- Brights Only On?
- Who Wants To Laugh At Dweet????
- Squeaking/grinding..
- Night And Day Driving??
- Freakin Speedo
- Power Window Question
- A-pillar Gauge Pods
- Rad. Hoses
- Idel Problem
- 25-50 Mph Acceleration
- Upgrading The Car
- How Do I Keep That New Clutch Feeling?
- Obx Header Install
- Need Help! Fuse Keeps Blowing!
- My Preticular 1.8l Cam: Answer Asap!
- Big Problem
- Mpg Increase With Certain Mod's
- 3a Racing Hi Flow Mufflers
- Some Quick Q's
- Help! Starting Issue..
- Compression Test
- Oil Pressure Gauge
- Power Steering Rack Leak
- Gas Gauge
- 97 Fx Body Parts Swap W/ 2001 Tib
- Confused About Rev A And Non Rev A
- What Is Eps Unit?
- Adding Cruise Control?
- Ummm Stop...ummm Help
- Hazard Output Wire
- Bbtb Options
- Tiburon Itb
- How Often Do You Wash Your Air Filter?
- Oil
- Wipers With A Mind Of There Own.
- Trip Computer
- Turn Signal Issue
- Just Got My Apexi Installed..
- Weapon R Secret Intake - What Do You Think?
- Motor Mounts
- Couple Of Exhaust ?'s
- Etacs/tacu
- Safc 2 Help Needed
- Shops In Southern California?
- I Noticed..
- Battery Cables Or Terminals?
- Maintenance!!!
- Fuel Consumption
- Cai Or Shortram?
- Removed Resonator And Air Duct From Stock Intake
- Straight Pipe
- Odd Idling... Only Sometimes Though
- Just Bought Pulleys
- Wheel Stud
- Aem Cai
- Cleaning Corrosion
- Bad Gas Milage What To Do (title Edited)
- Help Install E/H questions!
- Im in a rut
- CEL with newly installed custom CAI?
- Who removed their spare and jack for daily driving?
- I need to buy an o2 sensor, but where?
- Fan Problems...
- keep blowing fuses...
- hooking up oil pressure guage
- Gt Header pics and Questions
- Power Steering Pulley Removal
- IS this where the 2nd o2 sensor is suppose 2 be
- Window Regulator Install?
- trouble with my car
- changing my ECU
- Evap. Cannister Relocating
- Question about a Shift knob
- Need Help Getting Bolt off
- Well i sold the 2000 tib, but theres good news too!
- oxygen sensor output in millivolts
- 1997 Tiburon FX Crashed
- my new toy
- stock whp
- US spec apexi SAFC2 vs. J spec SAFC2
- Quick Question
- Aerodynamics 101
- What's Wrong with my Peddle?
- ebay hi-flow cats
- Recall Notice
- squeeeeeeeeaky clutch pedal.
- Vibration in Drive.
- Tuning ur Engine
- CAI Rubbing
- Another wonderful problem with the Maintec GT headers
- how often do u change headlights?
- What makes 1 CAI system superior to the next?
- What mod would you do first?
- What mod would you do first? (please delete it)
- 1.8L ecu question
- Problem of the day
- Camshaft Durations???
- vacume hoses ??
- wire ques
- Window Switch Idea
- Quick intake question
- wiring above the clutch pedal
- Reseting ecu
- 98 sonata = 2000 tiburon
- injen exhaust
- Loud knocking noise
- Will a phenolic spacer work in an Air Ram IM?
- Cat and O2 Help
- Vibrating While Shifting
- Headlight projection problems
- Powersteering pulley removal
- SAFC 2 install prob
- Bypass Valve?
- Any Hyundai dealer rep's?
- 2.7 V6 in a Tiburon 2000?
- Odd rattle coming from my high-flow cat
- Offroading problems
- Car won't start
- Tibs Getting Fixed
- Heat shield removal
- loud buzzing
- -=| (Tib 99') Replacement plastic peice needed with B&M S.S.|=-
- O2 gauge wiring
- throttle body gasket options
- Possible 02 problems?
- I need Korean RD ECU wiring diagram
- quick question
- ebay headers
- Hood Damper kit?
- oil change
- vibrations,
- throttle body problem
- Just ordered headers...
- 02 sensor help
- Can somone clearify this?
- full front end bushing kit
- Engine Bogging Down
- Engine Gurgling..??
- What can I do now?
- Frozen locks!
- Need help finding exhaust flange.
- Does this Exist?
- spark plug wires
- boring stock TB
- Gtech Pro?
- faulty alternator?
- ECU removal woes
- custom 2.5 mandrel
- OBX Exhaust
- Additional gauges question
- spark plug wires???
- I just proved that 3,000 mile oil changes, expensive oil and filter are unnecessary.
- MAP-ecu
- anyone tried this?
- These any good??
- 60k maintenance
- O2 Sensor?
- Vehicle Performance Computers
- Sigh I messed up :(
- Service Recall
- GT Header Pics anyone?
- quick pulley question
- CAI Question
- rebuild vs new
- Yet another noise..... (shocks?)
- CAi Using original Piping?
- Funny Startup
- Twin Engine Hyundai Tiburon
- Noob Needs Help with CAI Install
- smt6
- SAFC question
- Need help! Knocking noise!
- Tib wont start
- Diferance between 2000 and 2001 model
- Help!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Can someone photoshop for me
- kspecs intake cam vs 1.8L cam
- Easy Performance
- Heater
- Just thought this might be funny...
- 12.0 sec 97 Tiburon FX possible?
- Alternator removal/installation
- Funny sound....
- New header
- Getting to the ECU
- Problems with EVAP canister removal...
- Mechanical Spoiler
- Starting problems
- Alarm + ECU prob
- steering wheel stuck.
- Eyebrows
- Is my TPS going bad?
- Tuning with a Pocket PC
- Motoria exhaust help
- Extra Buttons in the dash...
- Aftermarket Exhaust, Stock Headers?
- Aircon Malfunction?
- Okay, weird Headlight issues goin' on....
- this header legit?
- Interchangable Parts List??
- Is it worth it?
- Cold Air Intake Heat Resistance
- Is stainless steel alright for CAI?
- Header question....
- 2.5" for an exhaust setup??!
- CEL codes - troubleshoot
- 1/4 times
- Is your ecu looks like this?
- central locking system
- a 4-2-1 header
- is this any good ebay jdm volt thing
- Headers..
- Gauges vs...gauges...
- Painting Cold Air Intake
- Do you know a good place to buy a cat?
- Car problem.....
- Where do you have your SAFC mounted?
- Need help finding a DIY
- Just got my Short shifter in and.....
- N/A Tuning for our cars
- gauges for n/a setups
