View Full Version : Hyundai Tiburon Forum
Pages :
1
2
3
4
5
6]
7
8
9
10
11
12
13
14
15
16
17
- Passenger Side Window Wiring
- Diagram Of The Stereo Brackets?
- Mass Air Flow Sensor
- F2 converted rd2 FS for scrap!
- Rpm Monitor
- Steering Loose. :/
- Stray Wires, What To?
- Fuses & Relays
- Location Of Fuel Pump Relay?
- Alternator Problems - Any Ideas?
- High Idle
- Stranded. Wtf Happened?
- Blowing Ecu Fuse
- Boosting Probs( Help)
- Timing Belt
- Signal Light Wiring Help
- Help With Replacing Starter?
- Sfr/kspec Turbo Pistons
- Got A P0455 Error Code
- Headers, 4-2-1 Or 4-1
- Gauge Lights
- Window Switches?
- Did A Few D.i.ys...pics
- Oxgen Sensor
- Catalytic Converter(s)?
- Need A New Garage! Toronto/york Region
- Tib Falls On It Face
- Jusat Installed Compustar Pro 2-way Alarm/command
- Fuel Pressure Sensor ?/ Info
- Radiator Hoses
- Stripped Bolt
- Viper Alarms... Advice Needed On New Alarm.
- Ac Condenser
- Power Steering Delete
- Missing Shtuff
- Head Lights And Cluster "pulsing"
- Sweet New Anti-theft Device
- Poor Performance After Misfire
- Obd Ii That Works Like A Hi Scan
- Cruise Control Troubleshoot?
- Driverside Melt Down
- 1.8 Cam Part Number Question
- steering hub
- Tail Lights At Full Brilliance With Parking Lights On
- Overheating Problem
- Need Serious Help
- Rough Idle/car Stalls Or Almost Does
- Egine Is Loudddd
- new green baby
- Twin Air Filters?
- 1st Gen Tib projectors...
- Car Overheating
- Installed My Ported Intake Manifold With New Injectors.
- Got Some Codes...
- Rheostat Wiring
- O2 Sensor Removal
- Defeating/removing The Security Torx Screws On The Mafs.
- Bulbs Blown, Cd Player Not Working.
- Reading Cel
- My First Real Post! 5 Speed Swap Done And O2 Sensor Question
- My New Ebay Exhaust
- Tiburons Good "beginner" Tuners?
- Prosport Gauges Rdtiburon Discount
- Air Bag Light?
- 45.6 Miles Per Gallon
- Threw On Some Blue Parking/turning Light Bulbs
- Clutch Kill Switch
- Unplugging The Fuse Wires?
- Rough Idle
- Tail Light Issue
- Having Trouble Filling Fuel Tank
- Key
- Oxygen Sensor Problems!
- Help With Starting Problem
- Vehicle Speed Sensor
- Video: Supercharged Hyundai Tiburon vs Subaru WRX
- Fast Ticking Sound In Fuel Line
- 2001 engine
- New Electrical Forum
- Cat Converter Review Thread
- New Wiring Harness - Vote!
- Couple pics from a shoot I had yesterday....
- Inline Fuel Pump?
- Msd Stacker
- Obd2 To Laptop
- Aftermarket Hood Pin's, What's Good For An Rd?
- Passenger Side Power Window Dead
- Motor Mount?
- 11 Mpg?
- New Exhaust Installed
- Window Welding Mounts
- How Do These A/f Readings Look?
- Help!
- Fire - Updated! With Photos 5-9-09
- temp pin & control
- Lookin For Thread
- Score! I Love Working Here Sometimes!
- Ever List Your Modifications For Someone...
- Aftermarket Alarm
- Floating Rpm's And Shaky Idle
- S.o.s Help! Possible Singh Groove Problem
- 1.8 Ecu And Cams On A 2.0
- I Need To Get This Car Running 100% Before Turbo
- Been Looking For a Cat Back For an 00 Tibby
- steering wheel?
- Maybe useful
- Reducing Belt Noise?
- Remote Starter
- My Little Big Problem
- Ps Belt Squeeling..
- Oil Catch Can Issue
- Performance Headers
- Ignition Connector
- A Little Tibbymat Update
- Half Core Installed
- Muffler
- Air Conditioner Cutoff During Acceleration
- Help Me Pick Out A New Muffler.
- Please Help With Diagnois! - Engine Bog Through High Rpm
- Got A Cool Shift Light... Help Me Install It!
- Heater Control Cable
- Keep Going Through Alternators
- Maf To Map Swap
- What Should I Do First?
- Pic Request: 2nd O2 Sensor Connector, Harness Side (rd2)
- Switch Wiring Options
- Return To Non Return Swap
- Help
- Dual Exhaust And Headers
- Short 30-55
- Cel P0303, 0302, And 00
- Pic Request: Airram Hose Details
- Silly Little Orange Lights
- Electric Issues ?
- P0445
- Exaust Smoke When Starting But Only In The Morning
- Header Options (which One)
- Fun With Charging Systems!
- Alternator Smoking
- Damned Idle Problems. 2k? 2300?
- Problems With The Dash Lights And Corner Lights !
- Engine Bay Wiring Mangement
- What Goes Into Calculated Load%?
- Help Weird Idle Problem And Weird Stuff In The Crankcase
- Sandwich Plate Leak
- Engine Stumble?
- 2000 Tiburon, Header/o2 Help
- Some Trunk Problems
- Odd Stalling Issues In An Auto
- Tensioner Pulley Bolt Thread Stripped
- Cel 1123 + 0442 & Bogging At Stop
- Turn Signal Problems
- Great Milage, Rough Idle!
- Belt Slip A New Approach!
- Gas And Trunk Levers
- Installing Hid Headlights
- Starting Issue
- Lots Of Smoke And No Brakes - Updated! Post #6
- How To Identify A Tiburon Fx?
- Oil Pressure Gauge
- Bad Vibration
- Turbo Exhaust
- Door Wont Unlock
- Water Pulley Alignment?
- Safc And Distributorless Ignition
- Help With Aftermarket Steering Wheel.
- Nice Front Strut Bar...
- Which Hid Kit Should I Buy?
- Sqeaking...
- Alternator Belt Snapped
- Help! 2 Check Engine Codes!
- Megan Racing
- H4 H.i.d. Problem
- Performance Exhaust Manifolds Vs Turbo Exhaust Manifolds
- Long Time No Post.
- Running Just Fog Lights
- Brake Light Led Bulbs, Which Wire For Resistor Loads?
- Which Muffler?
- Who Has Aftermarket Exhaust?
- Cooling System Worries
- Cannot Connect To Ecu
- Testing Mafs / Mas - Is There A Static Test For Mass Airflow Sensor?
- Fal 220 Blade Went Bust
- Boo
- Questions About Engine Head And Timing
- Rough Or No Starting: Trying To Diagnose
- Been Gone For Awhile But I Need Your Help!
- Drastic Increase In Performance And Mpg's
- Need Opinions Got Cel
- Will This Cause A Vacuum Leak?
- Anyone Using Larger Than Stock Throttle Body?
- Engine Specifics Beta 1 & 2
- Metal Valve Cover
- Increasing The A/c
- Starting Car Without The Starter
- Farshark's First Build - In Progress
- My Defrost Vents Aren't Performing...
- *help* Passenger Side Door Won't Lock
- My Tiburon...your Suggestions...
- Main Ground Not Connected?!?!?!
- Gas Mileage Isnt Where It Should Be
- Turn Signal Question
- Questions About Heater And Fuel Gauge
- Hvac Disconnected - Can't Start Engine
- Maximun Boost By Corky Bell
- Shark Racing
- Annoying Squeal
- What Do You Guys Think Of This?
- Belt Comming Off Pulley Problem?
- Free Automotive Electroncis Book
- Car Starting Problems
- White Smoke?
- I Realized Something Good About Old Cars Today...
- Removing Whats Left Of The Air Filter System
- Name That Part
- Ebay Catback Exhaust
- Engine Troubles. Help?
- Labled Pic Of Engine Sensors?
- Cold Air Intake Question
- Brake Lights Wont Turn Off!
- Cheap Canister Muffler?
- Just Failed My Second Emissions (smog Test Only) That I Need For My Tags
- Ebrake Light Stuck On?
- Exhaust Jack?!?
- Equal Length Discussion
- Another Exhaust Build Thread...
- Alternator Removal
- Bad Idle
- Starting Issues With The Accent.
- Sunroof Problems
- Wideband O2 Help
- Header Wrap Advice
- Battery Wiring?
- Kfx/flyryde/megan Headers On
- Help! Need Advice On Rusted Bolts
- Optima Blue Top Fit '01 Tib?
- Iac Rattles?!?
- How Big Is To Big For A Tb?
- Just Ordered Kfx Equal-length Header
- 2.5" Pipe Bender?
- Hyundai Tiburon Scheduled Maintenance
- Cars wanted at AutoMotif Group, Inc.
- I Think I Need A New Tps.
- Noise From The Lifters
- Weird Rubbing Sound
- Fuel Problem/sending Unit?
- Fuel Return Line?
- 30a Relay Question
- RD Series Diagrams & Instructions & Parts
