Floating Rpm's And Shaky Idle
Old Apr 28, 2009 | 09:05 AM
Slaved's Avatar
Hi All,
So from the research I've done, I've seen that floating RPM's can be cause by a faulty TPS right? Is there anything else that could cause this?
My other symptoms are a rough and shaky idle. I am just picking up the car now. I need to check the plugs, and rotor and such. Wires look good though. I also know there is an exhaust leak near the manifold, I read that could also cause a rough idle.
Any ideas?
Old Apr 28, 2009 | 09:07 AM
Tibbychick's Avatar
First thing you do, take a look at the TPS. It it says Kefico on it, you're golden. If it says Dae Sung or Bosch on it, chuck it and get a Kefico.
Old Apr 28, 2009 | 09:24 AM
Steezy's Avatar
Vehicle: 99/Hyundai/RD1
Do what Tibbychick said.. I'm about 90% sure that your car just has the crappy TPS..
Old Apr 28, 2009 | 04:05 PM
If you have a check engine light, mention that. If you don't have a check engine light on, then it is burned out, and you still need to get your codes read.
Old Apr 28, 2009 | 08:26 PM
Well, the Keifco's can go out too, so run through the normal list. New car? Get new plugs and wires.
And did you say ROTOR?
LOL
The rotors on our cars are in the brake system.
The exhaust leak, if the exhaust manifold is cracked, it's a manufacturer recall.
Old Apr 28, 2009 | 08:41 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
<div class='quotetop'>QUOTE (Tibbychick @ Apr 28 2009, 11:07 AM) <{POST_SNAPBACK}></div><div class='quotemain'>First thing you do, take a look at the TPS. It it says Kefico on it, you're golden. If it says Dae Sung or Bosch on it, chuck it and get a Kefico.</div>
Like REDZ said, the Kefico can go out also, mine did.
<div class='quotetop'>QUOTE (DTN @ Apr 28 2009, 06:05 PM) <{POST_SNAPBACK}></div><div class='quotemain'>If you have a check engine light, mention that. If you don't have a check engine light on, then it is burned out, and you still need to get your codes read.</div>
What would throw a CEL? Exhaust leak doesn't always throw, TPS doesn't and plugs/wires only would throw a code if it misfired.
Old Apr 28, 2009 | 08:45 PM
hamhead's Avatar
TPS throws a code.
Old Apr 28, 2009 | 08:47 PM
stealth's Avatar
I've gone through 2 TPS and neither have thrown codes.
Not all the time it doesn't.
Mine didn't.
Old Apr 28, 2009 | 11:31 PM
Slaved's Avatar
What kind of ignition system does this engine use?
I don't have any CEL, and I will check later on in the day if I have any codes.
The wires look new, I'll probably change them with the plugs anyway, just to eliminate them from the problem.
I have to check exactly where the exhaust is leaking, could be from the flex as well, I could just hear the leak closer to the front of the car.
I'll give you guys/gals an update when I manage to take care of these tasks...Thanks for all the help fing02.gif
