View Full Version : Hyundai Tiburon Forum
Pages :
1
2
3]
4
5
6
7
8
9
10
11
12
13
14
15
16
17
- Installing the header
- trans help please
- If a new Tiburon does come out
- Rare parts
- Beta swap Turbo (ABS and Airbag Lights)
- Clutch install
- Tiburon Posters
- New Tiburon?
- New Owner
- How dedicated are you to your car?
- Beta swap, Rebuild.. Waiting period (Clutch stuck)
- 2001 Tiburon, where is the Headlights On Chimer?
- The Aftermarket ECU Thread (Omex,Megasquirt,DTA ect)
- How do you clean microfiber towels?
- Stock cat failed, which aftermarket replacement?
- Disable Seatbelt Indicator in your Tiburon
- Interesting problem with a 2001 tiburon
- Wiring help? Drivers side day time lights! n DASH
- aem fic 6 question. urgent
- rd/gk compatability questions
- Hubs
- Any Tibs with Varrstoens?
- Whats the longest you've waited for a part to arrive?
- Weird start out in cold weather
- HELP! 01 Tiburon won't start, still turns over
- Is this real? How come I never seen them if it is
- Claybaring chrome
- Wheel Bearing/Clutch/Other Parts, 1998 Tiburon
- air intake/ exhaust
- Need Timing Belt change?
- 150,000 mile tune up
- Put on CAI, now High Idle and Bad MPG
- Stress cracks
- Longest you've gone between brake pad changes
- Header question
- 97 Tib Compatible Flywheel
- Misfiring
- Extra loud aftermarket exhausts
- can you buy engine restore kits ?
- 2.0 beta Injectors High Or low ?
- intake temperature and octane
- Headlights
- Whats the highest recorded mileage for a tib?
- Problem filling car up with gas
- Big exhaust leak on 01 Tiburon
- Who has the widest rim and tire on an RD?
- New 2001 Tiburon Owner
- The 2 most coveted things ever
- tips for port and polishing intake manifold
- Would this exhaust be too free flowing?
- Rebuilding water pumps
- Hard Start & High Rev
- Gates Racing Timing Belts
- Funny story...
- Structual rigidity?
- Frameless Windows > All
- electric cutout
- Did tibs ever come with tan interior?
- Chirping 2nd gear
- From Spain with love!
- Part-Out or Buy-Out? [Need opinions]
- We want to play too! Mileage thread for Tiburons
- I'm at my wits end with this one.
- What made you choose
- looking for radd rds chrome cap
- Wing Risers
- Sandblast oilpan for better heat dispation?
- RD2 cuda 1 body kit
- RD ecu's
- Do you have any nicknames for your car?
- Rside Advanced Shifter tweaking
- Check engine light
- Do the bottoms of the doors rust pretty easily?
- electric power steering mod
- need help
- The tale of two Tibs
- Head Work Question
- Painting the rear view mirror
- Compustar system
- Hole in my door?!
- Port & Polished Beta
- Backpressure test?
- What kit is this?
- Powdercoating an IM
- beta 2 5 spd transmission
- Engine sensors- Wire Colours (picture or text help)
- How much time do you think this took?
- slave cylinder spring removal
- Whos got the tiburon with the highest mileage?
- As anyone got the Beta Engine Wiring diagrams.
- Questions about my new Tib
- Think this will be too much red?
- Just bought the Android Torque app
- Megasquirt Owners PLEASE! :)
- Low profile side skirts
- Electrical issue
- i need a gk cluster diagram
- tiburons in tv shows
- Jack stand placement
- Messurements and angles of tib engines (picture help)
- Exhaust question
- OBD II Diagnostics Cable
- Matte colored tiburons
- IAC Valve/Motor Harness Connector
- M3 powered mirrors
- Rear Back up lmaps not working. :(
- Ticking Engine
- Need help
- Steel fender flares
- '99 FX mods
- Saw an orange Rd today
- polishing flat black factory mirrors
- If you had to do it all over again
- 2001 Tiburon - No Spark
- Where to get a complete timing belt kit?
- gk rear brakes help
- turbo rd2 problems
- Power steering pump
- Popping noise when turning left
- New guy wondering a couple things
- Projector lights
- Satellite radio
- Carbon fiber interior
- Project F8
- HID Hi/Low???
- Excessive oil burning
- Rust
- Removing condensation in foglights
- Who has had a reflash on their 2000/2001 tib?
- CF door trim
- Whats a good clutch to buy
- Will this fit
- RD2 painted headlights
- Stuffed animal sharks
- Sun Visor warning sticker removal?
- Clocks
- Progressive lowering springs
- Totalled the Tiburon
- Why would somebody need quick release fuel fittings?
- Crank and cam polishing
- Frozen locks
- Engine rebuild
- clutch slave cyl fix?
- Genesis owner just bought a Tiburon
- Cant find a Cupra R lip
- Questions about Koni shocks
- Sliding rag top for summer only car
- How to get this look?
- exhaust tip change, difference?
- Drivers side E-brake cables...
- Fan switch problem on manual H/vac control
- Engine Identification
- Borla exhausts for a tib
- Project FX Coupe: The Battle Continues......
- What is this?
- Blowby out of the oil filler hole?
- anyone know of grease that conducts electricity?
- Seam welding
- Tiburon Service Manual - G4GF/G4GM Engine specs
- Tune-up today
- Mold in the a/c
- If you own a 1997 tib
- Would this be ok for a rust spot?
- Iceman Intakes
- Aussie FX Coupe/Tiburon - I need info pleeeease
- Cleaning Carbon Fiber Hood
- Project LS, the 2000 Tib
- Are all GK tranny's the same?
- Looking for part numbers, Aussie help needed!
- Difference between eibach and H&R
- belt squeal/pullies slipping?
- How much are used tiburons in your area?
- Are Motegi MR7's too old school for a tib?
- Alignment Specs (I want good handling without the bad tire wear)
- no lug nuts fit! please help!
- Dynapack dyno question
- door sensor/switch?
- would these racing seats fit?
- Will putting spacers on wear out the wheel bearings faster?
- Moger's Updated 08 GT Turbo
- Gold pedal set
- guys i need help asap
- 08 Tiburon Supercharger/Turbocharger
- Anyone taking there tibbys out today in the snow???
- P1124 - long term fuel trim error-system lean
- To use dish soap or not to.....
- Question about 00 tibby fog lamps
- ECU disassembly/reverse engineering
- Auto Express Used Car Buyer's Guide - Hyundai Coupe/Tiburon
- How long do you have to drive your car after resetting the ECU
- body swamps 03-04 to 05-06
- Installing OEM cruise control
- Whats going on with my Alloys?
- OEM Matched Leather Shift + Armrest Boots
- difference between open and closed lug nuts?
- Getting close to 200,000 miles
- misfire
- gas light?
- Power Steering fluid cooling
- Will a clogged cat throw a check engine light?
- Clear coat over DINOC carbon fiber
- 5 speed shifting problem
- I found some ebay floor mats
- Dallas Area ?
- Tibfest?
- Put my tibby away for the winter last night
- Are Drag rims any good?
- Power folding side mirrors
- Warm / Hot starting problems
- How hard is it installing headers yourself on a V6
- Power supply for heated seats
- Idle problem and missing CEL indicator
- fuel pump
- UK center console different
- Anybody have 10 or 12mm spacers
- Direct Injection
- fan blowing direction - rd1 tib
- Speaker sizes
- How many diff style OEM wheels does the RD Tib have?
- NGM stealth turbo kit
- Bad Ass!
- HELP!! bushings for rear control arms
- Instrument Panel Connector colors
- Dumb drivers
- Rd2 dash conversation, Quick questions
- Theres an RD1 in this music video
- electrical diagram?
- Dallas area Tibs
- Dry Sump Conversions
- purge control solenoid?
- Never seen this hood or body kit before
- PLEASE TELL ME THESE WILL FIT!
- Unknown RD2 Body Kit
- Lowering RD2
- RD2 Gauges ?
- New Guy here :)
- Rd2 bumper on RD1 Tiburon
- HELP! check engine light came on
- Fender Marker lights
- Good place to buy braided hoses and lines
- Boge lowering springs
- Is there a Tiburon Hotwheel?
- carbon fiber wrapping hatch
- Performance chip for a GK??
- 18" sub in a tib hatch
- Will GK sway bars fit on an RD?
- Hatch brake light
- HELP !!!! Whats wrong with my engine??
- Whats your favorite lip?
- Acrylic LED Door Sills
