- Cruise Control
- Engine Bog/dying
- A/c Condenser Problems?
- Bluestreak Plug Wires
- Finally My Exhaust Sounds Good
- Cold Air Intake Vs. Short Ram Intake
- What To Buy Next.
- What Car Alarm Do You Use?
- Battery Relocation/optima/odyssey Battery Questions.
- Help Troubleshooting
- Broken Tps
- Obx Radiator Hoses
- Wipers
- Colt Cams
- Euro Evaporation Canisters
- Please, Little More Info.
- Scanned The Car, Need Help
- Ecu Wiring Diagram
- Me Fixing And Oil Leak
- New Setup
- Quick Performance Checks
- ?piggybacks?
- A'pexi Exhaust Clip.
- How Do I
- Carquest Warranty
- Obx Headers
- Question About My 2.0l Tib Before It Goes To The Junkyard
- Cabin Filter Question
- Camshaft- Legit?
- 1.8 Ecu Installed
- Microtech Lt-10 Ecu
- Smt-6 And Emissions
- A-pillar Pods
- All That E-bay Junk
- Stupid New Battery.
- Cel P0102
- Problem When Filling Up Gas
- Exhaust- Need Your Opinion
- Car Wont Start.
- Front Seatbelts Locked?
- Spark Plug?
- Acid Dip
- Mitsu Long Block With Tiburon Head?
- Epoxy Resin Instead Of Polyurethane For Engine Mounts?
- Reverse Lights Don't Work
- After Accident Effects
- I Got A Question About Exhausts
- Power Difference Betai Vs. Betaii
- 1.8 Pistons
- Crazy/weird Short Ram Intakes.
- Fwd To Rwd
- Interesting Way To Increase Gas Mileage
- Air Bag Sensors?
- Fuel Cell
- Finally Equal Length Tubular Headers! Pics Inside!
- Engine Sputtering
- Reving Engine?
- Problems Starting
- Performance Questions
- New Radiator Question ?
- Fast Lane Daily Spy Shots New Tiburon
- Ridiculous Security System: How To Turn It Off?
- Turn Key = Nothing?!?!
- Revamped Stock Throttle Body
- Car Wont Crank
- Plugs & Wires
- Defrost Stuck On A/c
- Brake Light
- Catalyst Below Threshold
- System Gt-r 61mm Bbtb, Any Good?
- Fuel Economy
- Lighting
- Progress On The Oil Catch Can
- Heater Vents
- Electrical Short
- Rd2 To Rd1 Exhaust
- Weird Question.
- Lug Nut Problems
- Whats The Most Common Intake Manifold For Our 2.0s?
- Car Only Starts Half The Time!
- Relocating Evap For Intake...
- Cold Air Instake
- Thinkin Its My Tps..
- Urgent Help! Stalled Posting From Cell Phone
- Obx Header Problem?
- Vent In Trunk
- Help! Asap!
- Custom Made Headers
- Oil Catch Can
- Screwed Up Heater Control...
- Bad Alternator?
- Engine Measurements
- Exhaust Cam Modification
- Changing Automatic Gear Knob
- Obd Scanner For Osx
- Remap Ecu And Raise Rev Limiter!
- A/c Leak
- Turbo ?
- My wife's tiburon
- Installing A Fpr
- So You Want A Custom Exhaust...
- My Tib
- Airbag Light Is On
- Which Weighs Less Gutted Out? Rd1 To 2
- Why Don't My Subs Work?
- Civilized Debate Air Ram Vs. Stock
- Whiteline Strut Bar?
- Power Windows Not Working ?
- Need Help With Cai
- Loss In Power Steering With Lightened Pulleys Installed?
- Blizaga Finally Bought An Exhaust
- My Exhaust Setup
- Security System Info
- Window Not Working
- Gas Mileage
- Weird Idle Issue Caused By 1.8 Ecu
- Vehicle Checkup
- Big Obx Problem
- B12 Vs. Seafoam
- Vehicle Speed Sensor Range/performance Reading
- Smt-6
- Who Can Chirp 3rd N/a
- Electronical Schematics
- Most Effective Oil Catch Can
- Exhaust Help Needed
- Found Some Weatherstripping In My Sunroof
- Front Intake?
- Cf Hood + Rain/ Snow = ?
- Fuel Delivery Problem? I Cant Figure It Out....
- Gps Speed Sense Wire
- Overheating
- Help Removing Lower Ball Joint From Control Arm
- Some Advice Maybe?
- License Plate Is Expiring Next Month...
- Aftermarket Gauge Problems
- Damn Compression Fittings
- Stuttering And Cel Problem
- Power Loss In 1st Gear?
- Motor Mount ?
- H E L P >... Owned Myself...
- Bike Carrier?
- Cut-off Question ?
- Somebody Help!
- New Intake Manifold
- Which Engine Is Better For Me
- Oil Pressure Guage Question
- Coolant Hose Leakage
- Ongoing Dash Light Problem
- Code P1128
- Cam Angle Adjustment Sensor
- Exhasut Help Needed
- Wdymtw: 13-15 July
- Just Need Some Info
- Sunroof
- Found A Tib In A Junkyard
- Has Anyone Experienced Cheap Exhaust Work?
- Need Help Finding A Muffler & Unique Exhaust Tip.
- Woohoo! Awesome Quote On A New Exhaust.
- Clogged Cat - Flush Or Replace?
- Pre/post Maintec Videos/pics
- How Should A 1.8l Cam Sound?
- Carpet Cleaning Help Needed
- DTNs rendition of Redz accident
- Wow
- Should I?
- Problem With Signal Lights
- Warranty On Prd Wires..
- Power Steering Flush And Fill...
- Impressions: New Ark Exhaust
- Alternator Fuse?
- Radiator Size...
- Intake Wanted!
- Rd1 To Rd2 Front Conversion?
- Problem With Tail Lights
- Fuel Rail
- Post Your Pcmscan Maps!
- How Do I Come Off?
- Got The Kdm Plates..leave My Car Plateless? Or No?
- To Coat Or Not To Coat?
- Steering Wheel Vibrates
- Catback Bolts/gaskets
- Tail Light Fuses..
- Radar Detectors
- Imput On My List...
- Surging Problem
- Car Wont Crank
- My Car Has Two Major Boost Leaks
- Exhaust?
- O2 Sensor
- Auto Windows
- Erz Headers?
- Info Needed
- Alert For Ssac Headers
- New Exhaust
- Subwoofer Box
- What To Buy
- Inspection In 5 Days And I Need Help
- Will This Be A Problem?
- Messed Up Power Locks
- 6-12-2007 Photoshot
- Help My Trany Wont Disengage
- Crank Pulley Question
- Stuck Rotors
- A/c Not Working
- Cat Efficiency?
- Help! Car Won't Start.
- Crank Sensor Trouble
- My Rd1 Gas Tank Is Backflushing. Help
- Msd
- Please Help Fuel Filter
- Leaky Injector From O-ring
- Car Is Acting Funny
- Oem Timing Gear, Fidanza Timing Gear.
- Sunroof Questions
- P0131, P0135, P1513, P1553
- Apexi Safc 2 Problem
- General Performance Questions
- Need Help
- Tiburon Questions
- Muffler Question
- Poor Gas Mileage...
- Finally Got My Headers Installed
- Slow Wipers.
- Cel P0136
- Fuel Problem?
- Fuel Filter
- Nitrous Lines Tapping And Tapping
- Spark Plug Wire Boot Stuck
- Need A Better Spark Plug
- Car Shaking
- Header Install Question
- New Exhaust Setup
- Spark Plug Question
- Wdymtw?
- Exausth Info !
- I Blew Up My Freakin' Intake!
- Alternator Almost Out - I'm Stuck!
- Headlight Alert
- I'm Stupid And Thanks Jay-m
- Aem Uego Gauge In Action
- Exhaust Help
- Port And Polish
- Fixed: Extreme Deceleration
- Question About Messed Up Tps And Maf
- I Have No Power
- Need T-bolt Clamps
- Cel
- What Does Your Exhaust Sound Like?
- My Exhaust
