Oil Pressure Guage Question
i just got done putting in my sandwich adapter for my oil pressure guage. when i first start the car the guage reads 60 psi. then after it warms up it goes down to about 32psi and when i rev it up to 4000 rpms itspike to about 70 psi. my question is, is that normal or do i have something wrong? id appreciate all the help i can get
alex
alex
that sounds right.. not only do modern engines run higher pressure due to their tighter tolerances, but oil pressure is NEVER a steady psi. The faster the engine goes, the faster the gears in the pump turn, moving more oil and under more pressure.
Temperature plays a part too. Cold oil moves slower, but builds more pressure than warm
Vehicle: 01 Tiburon
it's all good man
all you really have to watch out for is the oil light on the cluster... other than that, you'll be fine
