PDA
View Full Version : Hyundai Tiburon Forum
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17
  1. Turbulence Inazma Wire
  2. Obx Header
  3. Is My Car Some Sort Of Mad Bastard Sent Back From The Future?
  4. Want To Turbo
  5. Anyone Got Connections For A Cnc Job?
  6. Turn The Wheel But The Car Goes....straight?
  7. Idle Bog
  8. Drilling A Tensioner Pulley
  9. How Do I Fix My Damn A/c?
  10. Tb Qs
  11. Msd Second Option...
  12. Jspeed Power Pulley
  13. Ccv Code
  14. Tachometers
  15. Its Been A While, But I Need Some Help.
  16. Blown Fuse
  17. Timing Belt Swapped At The Dealer For $485 All Included
  18. Short Shifter Showdown #1.
  19. Apexi
  20. Exhaust Question
  21. Clogged Cat?
  22. Help With Pulley
  23. Twin Loop Muffer
  24. What To Do
  25. Headers
  26. 1 Years Worth Of Mpg Data
  27. Fuel Injector Question
  28. Remus Catback
  29. Help Fuel Pressure Regulator
  30. Radiator Fan Question?
  31. Leaking Pretty Badly
  32. Map Sensor Location
  33. Strut Bar Questions
  34. Question About Exhaust Hangers
  35. Gauge Questions
  36. Help Needed: Airbag Light On, Bright Fluctuating Instrument Lights
  37. Leaking Coolant Mang! Need Help Quick!
  38. Picture Request
  39. Differential Oil: What? Where? How Often?
  40. Na Or Turbo
  41. Lpg Conversion Is Done!
  42. Emergency Lligths Dont Work
  43. Air-ram/65mm Tb Install Afternotes
  44. Why Is The Rd Korea's Most Popular Tuning Platform?
  45. How Do You Install A New Aftermarket Tach
  46. Flex-pipe
  47. P0453
  48. Pyggyback Ecu
  49. Electrical Mystery..........
  50. Besides A Turbo
  51. Electrical Problems? Fuse Information Here
  52. Blown Fuse?
  53. Screwdriver's Additive Regimen
  54. Battery Voltage
  55. Exhaust Question
  56. Another Sound
  57. Water Leaking Into Triple Pod.
  58. Ecu
  59. Having Some Serious Problems
  60. What Happens When Your Fans Dont Have Wiring...
  61. Weight
  62. Headers
  63. Cai Clones
  64. Apexi Rev Display W/ Safc2
  65. Bbtb Sticking
  66. Power Chips
  67. Kspec Timing Kits
  68. Where To Get Dyno'd In New Jersey?
  69. Strange Fuel Pump Problem!
  70. 2000 Elantra Muffler -vs- 2001 Tiburon Muffler
  71. Power Windows Won't Roll Down
  72. Exhaust?
  73. Prioritising Performance Mods
  74. Vacuum Manifolds, Beta 2 Airram Fits.
  75. Brake Light Stays On
  76. Thinking About Doing This Myself...
  77. Headlight Alignment - Rd2
  78. Just Told About Recall On Exhaust Manifold
  79. Gauge Install Ideas
  80. 2000 Vs. 2001 Gauge Clusters
  81. Coolant Overflow Tank Temps
  82. Cheap Cowcatcher
  83. Turn Steering Wheel And Horn Honks
  84. Timing Belt Kit
  85. Wiring Up Oil Pressure And Boost Guage Lighting
  86. Short Shifter Showdown
  87. Battery Life
  88. I'm So Confused About That Exhaust...
  89. I Got A Dilemma & I Can't Seem To Find The Root Cause.
  90. 5w-50
  91. High Idle
  92. Motoria Catback..
  93. Weird Exausth Noise !
  94. Tibs On ALTERNATIVE Fuel
  95. Funny Codes--check Engine Light
  96. Cluster Lights No Worky!
  97. Car Wont Start :( Please Help.
  98. Ka-power N1 Style Straight Cut Burn Tip Universal Muffler W/silencer (ka-rs310t)
  99. Needed: Instructions For Rside Basic
  100. Battery Relocation Electronic Help
  101. Clutch/brake Pedal Non-rice Replacement
  102. Por 15 Check It Out.
  103. Racing Seat Brackets
  104. Just Came In From Kspec (no 56k)
  105. Throttle Body Benefits
  106. Where Do I Buy This Kind Of Spoiler?
  107. Need Ecm Pinout
  108. Tb Question
  109. Need To Fix Exhaust.
  110. Gear Knob Question
  111. 4 Cels And A Couple Bad Sensors
  112. Gauge Clusters For Rd2
  113. 2001 Ecm Pin Out
  114. Guess What Went Away Today?
  115. Both Turn Signals Come On
  116. Need Some Help And Direction...
  117. 53006 Magnaflow Carsound 2.5" Catalytic Cat Converter
  118. Airram Installed! With Strut Tower Bar
  119. Crackey Cylinder Head?
  120. Fuel Pressure Guage For Aeromotive Fpr
  121. Prices For Im Swap.
  122. Hazards/turn Signals Not Working
  123. Remote Start Problems
  124. Silencer In Muffler
  125. Help ! Crazy Problem
  126. How Do You Install H4 Lights In Tib?
  127. Wires?
  128. Winshield Washer Squirter
  129. Motoria Silencer Won't Stay On
  130. Where Did It Go?
  131. Won't Start..whirring Sound
  132. World Fastest Tiburons
  133. 1.8l Cam Sounds
  134. Best Short Shifter For The Rd1?
  135. Fuel Shut Off
  136. Cai Vs. Wai Vs. Stock Box + K&n Plase Help
  137. Help! Replacing Thermostat!
  138. Aem Cai Parts?
  139. Wierd Noise...
  140. A/c Compressor Squeeling
  141. Gas Mileage Going Down And Down And Down And....
  142. Turbo Or Tranny Swap?
  143. Headers Installed
  144. Whats Up With Www.speed-factor.com
  145. Look What I Did
  146. 2001 Tibby
  147. Something Happened To My Tib
  148. Nopi Workups...
  149. Resonator Removed - Why Bother With Cai?
  150. New Muffler Vs. Catback - Any Difference?
  151. Headers And Catback
  152. Strange Grinding Noise During Cold Startup..
  153. Short Shifter Wont Fit?!?
  154. Exhaust Q's
  155. Spolier Leds Wont Work
  156. Rusted Headers
  157. Keyless Entry
  158. Intake Valves
  159. Stock Flex Pipe Size?
  160. Grinding Soud From Rear
  161. Rpms At Somewhat High Speeds
  162. Need Exhaust W/high Flow Cat
  163. Dual Exhaust?
  164. What Type Of Gauges...
  165. Turn Signal
  166. Other Brands Of Stuff
  167. Where's The Ecu
  168. Gauges
  169. Exhaust Grounding?
  170. Strange Humming Noise/ Rough "feel" At 55-65 Mph
  171. 00 Tib Problem Acceleration Problem
  172. Prove To Me You Have A Better Maintained Tib Than Me
  173. Temp Gauge On The Fritz!
  174. Mods To Compliment Future Turbo?
  175. One Last Shot..
  176. Cruise Control + Rside Bbtb?
  177. Cai And Auto Carwash
  178. Safe Jacking Points?
  179. Help!
  180. I Need To Get Power
  181. Whats Wrong With This Auction
  182. Catch Can ?'s
  183. New Cel! Dammit...
  184. Turbo Timer Install Problems
  185. No Lights?
  186. Aem Vs Injen
  187. Best Bang For The Buck?
  188. Sticky Bbtb
  189. What Ya Think
  190. Damn Cel Wont Go Away!
  191. A Little Problem With..
  192. Speedometer/windshield Wiper Fuse
  193. Idiot Lights
  194. Exhaust Help
  195. Rubbing/grinding Noise!
  196. Airram, Bbtb, Outlaw Spacers Dyno's !
  197. What Is This?
  198. Xenon Kit
  199. What Bbtb?
  200. Boy Did I Save Alot Of Money.
  201. Couple Questions
  202. Removing Wheel Well?
  203. Rside Bbtb Install
  204. Porting Im
  205. Recommended Motor Oil?
  206. Strange Rattle/buzz
  207. Alternator Questions...
  208. Which Headlights?
  209. Bad Lag
  210. Obd2 - Pc
  211. Icey Roads :( Help Me Fix My...
  212. Ebay Turbo Kit
  213. Outlaw Engineering
  214. Whole Bunch Of Random Questions
  215. Noise When Turning
  216. Airbag Light
  217. Service Checking
  218. Digimoto Information
  219. Coolflex Hoses On Sale
  220. Where Can I Find Juntos Stuff
  221. Anodized Fuel Rails...
  222. A-pillar Pod/ Guages
  223. New Muffler For Motoria...
  224. Big Debate....
  225. Exhaust
  226. New Spark Plugs!
  227. Quick Cam Question
  228. Rs Type Short Shifter?
  229. Rd2 Headlight Issue
  230. Random Engine Cut Off When Coming To Light And Braking Hard.
  231. Hid's In...
  232. Best Parts Store Ever!
  233. Haltech Ecu And Getting The Dash Taco To Work.
  234. Header,install,oops!
  235. Header + Exhaust In Gta
  236. Cold Start
  237. What Data Does Ecu Store?
  238. Gas Milage Part 2
  239. Hesitation: Spark Plug Wires Minimum Ohm?
  240. Gas Milage?
  241. Fuel Line
  242. "shaking" While Accelerating From A Stop
  243. Looking For Some Opinions
  244. Idiling Problems
  245. Is This True?
  246. Another N/a Question
  247. Grinding Metal
  248. Elantra Tps Sensor
  249. Need Suggestions
  250. O2 Sensor(please Read Before Closing)
