Grinding Soud From Rear
Old Mar 5, 2006 | 10:12 PM
Phenomenal_Thunder's Avatar
my car has been making a grinding noise and it sound like it is coming from the back. I know its not the brakes because the brakes were changed 2 weeks ago. and it was making the noise before i changed the brakes too. just trying to see if anyone know what it could be. thanks for the help guys
Old Mar 5, 2006 | 10:13 PM
zoned019's Avatar
Vehicle: 97 Tib
Seized up caliper?
Wheel bearing?
Give us a little more description...when does it do it? What exactly does it sound like? When did it start?
Old Mar 5, 2006 | 10:16 PM
tibatron's Avatar
i got the same thing 02.gif ..i think mines a wheel bearing though
Old Mar 5, 2006 | 10:22 PM
if anyone is having a rear bearing problem FIX IT ASAP seriously its rediculasly easy if you have rear drums and i bet just as easy for disks
i had one lock on me doing 80 on the freeway
it caused my hub to lock in place and basically LOCK my brakes only in that rear tire
i span like 8 times came really close to the guard rail
total damage cuz i didnt wanna buy a $40 part
new tires - 280 bux(crazy bald spots on all 4 from the braking)
new pads - 60 bux
new drum - 100
new brake cylinder - 65
new springs for the drums - 25
hub - 45
ebrake cable snapped - 45
blown strut- 45
alignment-65
Old Mar 5, 2006 | 10:27 PM
tibatron's Avatar
thanks man..now ill be nervous as hell until i fix it sad.gif ..which im sure now will be very soon..if i spin out im buying a lambo...or pinto..
Old Mar 5, 2006 | 10:28 PM
it does it when i apply the breaks. it started about a month ago. it just sounds like grinding, i dont know how else to explain it. i drive a 2000 tib by the way. thanks
Old Mar 5, 2006 | 10:29 PM
well if its only happening when you apply the brakes
ever think your brakes may need changin?
Old Mar 5, 2006 | 10:30 PM
oh really, that is a great idea!!!!!! to bad i said in the first post that i changed them 2 weeks ago smile.gif
Old Mar 5, 2006 | 10:31 PM
you may have changed them
but did you adjust the ebrake cable?
install them right?
did you get the drums cut?
Old Mar 5, 2006 | 10:33 PM
they should be installed right, i had it done at a hyundai dealership smile.gif
