- Additional Info On Unknow Body Kit
- Can Anyone Figure Out This Body Kit
- Where Is The Best Place For A Wideband O2 Sensor?
- New Brake Stuff(and Some Questions)
- Interior Lights
- More Stupid Questions
- Gas Mileage?
- Guaranteed 50+hp And 50+torque!
- Rough Shifting From First To Second At High Rpms On An 01 Tib ... Help!
- Exhaust Restrictor
- Sound Check..1.....2....
- My updated shopping list for my Tib
- Anti-freeze
- Wdymtw: 9-20-2008
- 300kph Gaudge
- Airbag Light On
- Car Stalls At Idle
- Help An Elantra With The Same Heart As A Tibby?
- Cv Joint
- 02-07 Tiburon have the same motor as 02 Elantra
- Future Paint Ideas
- Headers on your Tiburon
- GK BCM Assembly and Turn Signals
- Gas Tank Overflow?
- Looking For Replacement Bushing
- Seatbelt And Light Alert Chimes Won't Shut Up
- Was Bored Today
- Need Help..oil Light
- Diy Needed!
- Rpm Going Down Faster ?
- I've Done The Innevitable
- Singh Groove Discussion
- Oil Cap ?
- Help! Acceleration Problems!
- Electrical Issues...
- Bad Decision
- Leaky Fuel Filter...
- Update On Optimoprime's Tib
- Anyone know anything about this CEL code?
- Difference In Port And Polish...
- Engine Dies, And I Miss My Flight... I Got A Short!
- Other than the hood emblem, I really like this Tib....
- Is There A Cut Off Switch For The Fuel Pump?
- Rd1 2.0 Beta Vs Gen 3 2.0l
- Need Help! Car Wont Start
- I finally got my tib fixed
- 97 Tiburon Gas Tank Recall
- My first noob question
- Car Still Wont Spark (will Still Turn Over)
- New Tiburon Owner
- Any1 Know Where I Can Find This?
- A/c Recharge Help
- Headlights Not Working
- Replacement Fuel Filter?
- Killer Glass Hoses And A Water Temp Gauge
- Ok Ecu ?
- Hurray!
- My New Dual Catch Can Setup.
- Kia Sportage Problem
- Car Troubles.. Rumble Rumble..
- Window Motor From 98 Fit 01?
- Finding A Catback
- 60ft Time ?
- Really Simple Question Pcv Valve
- 2001 Tiburon Vibration/noise, Please Help!
- Help Pleast Tibby Trouble
- Learning How To Ride.
- Help my Tib
- Ecu Switch?
- Cars wanted at TWM performance
- 02 Sensor Wiring
- Sad Day...
- Computer Diagnostics Calculated Load Value
- Gas Pedal Unresponsive?
- Boost Gauge Or Vacuum Gauge?
- A/c Recharge Not Working?
- Installing A Remote Start
- Ac Squeel?
- I Need A Catalytic Converter
- Problem With Cruise
- No Speedometer Or Odometer
- Header Noise
- Windshield Washer Pump
- Apexi Neo
- Idle Problem With A/c
- Problems .. Cels ..
- Anyone Near Napa Valley?
- 1.8 Cam & Lopey Idle?
- Replacing Your Primary O2 Sensor
- Invidea Catback System
- Did The Swap, Mostly Done!
- What Gen?
- Want To Be A Moderator
- Looking For My Old Tib
- Oem Under Hood Fire Liner
- My Custom Exhaust
- Safc2 Question
- Supercharging The Tiburon - My Experience And Thoughts
- What Do You Think?
- Need Help
- Fuel Pump Not Working
- Getting Some New Stuff Today!
- Belts.
- Maf Sensor Wiring Size
- Dual Exhaust System
- Airram/hood Clearance Prob
- Rusty Bolts
- Cai Pricing
- Driver Side Seatbelt
- Gas Station's
- Wideband Mounting Point
- Quick Exhaust Question
- Rust And Dirt Traps You Cant See
- Weird Problem
- Intake Manifold
- Cold Air To Supercharger Idea?
- Rd2 Shutting Off For No Reason?
- Carpc Info Needed
- Electric Problem?
- Mr. Taillight High Beam Fog Light Kits
- Electrical Problem - dash lights when braking, brake lights with headlights
- Kjb Delrin Shifter Bushings
- New Muffler For 98 Tib
- Anything
- Burning Spark Plugs
- Cel P0138..
- Frame Section On Tib
- Cv Joint
- Exhaust Question
- Light Bulbs/leds And Such
- Need A Little Help
- Cai & Ebay Any Suggestions?
- Wiring Diagram For 2000 Tib
- How Do I Fit A Boost Gauge To An Alpine Supercharger?
- Ecu Harness
- Radiator Fan Wiring
- Popping When Apply Brakes
- Clutch Pedal Position
- Bad Idle When Headlights On.
- Piston Confusion
- Car Wont Start
- Voltage Stabilizer
- My New Strut Brace...(finished)
- Rolling Idle
- Hey Rd2 Guys....gt Tech Update!
- Oil Filter Magnets
- Quick Oil Drains.
- Header
- Revision A Cannister Removal.
- Help With Fpr
- Smaller Alternator Pulley For Higher Output?
- Problems With Spark Plugs?
- Recommended Air Tools
- Horn Problems
- Ram Air Design Problem
- Disassembling Throttle Body
- Online Parts Catalog?
- Problem With Reverse Lights
- Extending Alarm Antenna
- Safc2 Problems
- Impact Gun, Electric Or Air?
- Short Shifter Problem
- Hood Latch Cable
- Can You See The Differences?
- Connecting Multiple Power/ground Lines
- Fuel Injector Type
- 1.8 Pistons, Revisited
- Grinding Sound In Back Wheel
- Finally Installed Exhaust
- Tachometer Signal From The Gauge Cluster
- Bse Ecu Chip
- Question About Pedals
- Are Intakes Transmission Specific?
- Blue Top Optima Battery
- Zoned's Exhaust Done
- Ebay Short Ram's
- Custom Exhaust Is Done!
- Hids Acting Up
- Exhaust/resonator Help.
- Remove Frontpanel (installation Vertical Door Hinges)
- Ckp Sensor
- headers for 2005 I4 tiburon
- Something Is Wrong?
- Car Making Weird Noises When Turning Right
- Omfg Car Wont Do A Thing
- Starter Help Needed Fast
- Water Pump And Timing Belt
- I Need A Ho Alt
- Check Engine Light -.-
- Ok...what Did He Do? *lol*
- Broken Wire.. Need Suggestions.
- Fluid Leaking...
- Air Bag Plugs?
- Question About Exhaust
- Bolt Thread Size?
- Quick Help
- Quick Question
- Tool Recomendations
- Problems Trying To Get New Radio/tv To Work
- Maintenance ?'s
- Carbon Fiber Hood Vibrating Annoyance :(
- Headlight Adjustment
- How Did Things Work Out?
- Frost On The Inside Of My Windshield?
- Working Out Bh
- Window Wont Roll Up
- Hatch Wont Shut
- Decision Needed On What Parts To Order
- Need A Pic Of Rd1 Passenger Engine Mount
- Car Control Problem
- 05 Tib Need Help
- Pcv 002
- Didn't Knew I Was Faster Than A Bmw
- Belt Or Bearing?
- Sniper Tuning
- A/c Condenser Install Questions
- Possible Problems
- Corrosion In Cooling System !
- Mpg
- Replacement Bulb Guide
- Acceleration Sensor?
- Stock Exhaust No Muffler
- Ebay Catback
- Spark Plug Wire Question
- Blower/fan Knob Not Working?
- Killer Glass Radiator Hoses
- Bodywork (panel Removal Question)
- What Does Maf Do?
- Injen Style Air Intake Question
- Cat Back
- Autorx
- Quick Question
- No Reverse Lights
- Oils Going Somewhere
- Gas Milage List And Suggestions
- Mpg Killer?
- 130 Whp At 4000 Rpm....does This Sound Good?
- Defroster - A/c
- Weird Connector Behind Tb.
- Timing Belt Change Notes, Thoughts And Follow Up
- Weird Noise Comming From Car
- Blowing Fuses / Headlight Issue
- Clock Problems
- Rpm Switch
- Clutch Fuid
- Gas Pedal Squeeking ?!
- Dash Swap Rd1 To Rd2
- Gas Economy
- Good Deal, Or More Ebay Bs?
- 1.8 To 2.0 Header
