- Fuel tank swap
- Movies that RD's have been in
- Replacing rubber moldings around windows
- Looking for OEM 5spd Shifter Position Pics
- Gas door lever rusty
- What the hell!!??!!??
- Car turns over but won't start..
- tranny
- So why exactly did the GK's get way more aftermarket support than RD's?
- 08 front clip on 06?
- Type-R wing for RD2
- Does anyone know what lip this is?
- ECU
- Elantra marker lights compatible with RD1?
- Exhaust questions
- Best procedure to get your tib up on 4 jack stands?
- Cooling system help
- Putting the tibby on a diet
- Air Conditioning
- The Greatest Achievement Ever!
- Xspower
- 97 tib revision A still in perfect condition
- Radiator help
- Best spot to mount Valentine-1
- Just bought a 98 Tibby with a I think a bad Auto tranny?
- Mode $06 On A Tibby
- Obd Port Work
- Hid Installtion
- Soundproofing wheel wells
- Windshield Wipers
- Check out this center console
- Is the tiburon still one of the top most stolen vehicles?
- Do you keep anything in your door pocket?
- Will This Work?
- E-brake cable
- 02 Sensor And Check Engine Light
- Help With Sunroof
- Trunk/Hatch poppers
- Question about carbon fiber
- Emanage Ultimate Ignition Fix
- Header Question For Canadians
- Tein S tech or Eibach Sportlines?
- Stalling
- Drivers window versus Passenger windo
- Exhaust system or cai first?
- Oil pan gasket
- Silicone spray with heat wrap?
- Magnaflow Catalytic Converter Rattle
- 200 horses all motor?
- How Do You Get A Door Off? Bent Hinges?
- I Need Help. I Need A Mode $08 Scan
- Longevity?
- Difference Between Hla's Mlas
- Wing or wingless tiburon?
- Turn Signal Goes Without Being Touched.
- Need Help/support
- My Tibby Is Alive Again!
- Wonder if anyone ever truly did buy this kit...
- Over-did It Jump Starting A Bigger Engine...got A Problem And No Code.
- Hyundai Gds Update
- Turn Signals Are Messed Up.
- I Made It! (200,000 Miles) Status/update
- Wobbly windows
- found a pretty good kit car model!
- Rd2 Foglight Questions
- A/c Squeal
- Seat Belt Jammed And No Speedo/tach
- Flex Pipe
- No Cat
- Evap Large Leak
- What Parts Are Likely To Fail At High Mileage?
- Reverse Glow Gauges for 00-01 Tiburon?
- Engine Flush?
- Black Smoke
- Injector size
- Led Project
- Gk Exhaust On Rd2
- Car Won't Start At All
- Engine Block Coolant Drain Search
- TPS voltage
- Rear Washer Switch
- Trip to the strip.
- Sick Of Hla's
- Help!....tired Sonata
- Turby sideskirts
- Oil Block Adapter
- when good things come from bad.
- Crazy Rattle, Please Help!
- Whats next?
- Ive never had a coolant flush
- Purge Contol Valve
- Door Locks
- Intake Manifold
- Dual Exhaust
- ash tray mods?
- Gas Tank Problem !
- Will Swapping Instument Cluster Reset To Original Mileage?
- I Dont Know Which One To Do First
- radio wire harness?
- Replacing Hood Latch Release Cable
- Obx Pulleys
- Car Alarms
- Wheel bearings
- Crank And Maf Connectors
- 08 instrument cluster on a 03
- Dry rot on tires, Anyone experience it?
- All you regulars, prepare for a flood!
- Check Engine Light, P1124... Help!
- So My Windows Leak..
- tib lip kit
- Is This Right?
- In A Jam With My Cai..need Help Asap
- Wdymtw 9/14-9/21
- Rust
- Difference between auto and manual a/f ratios
- Best Looking Globes Without Hid Kit?
- Ball Joint
- Maf Wiring
- Cd/tuner Wiring Rd Tiburon Compared To 2003+ Getz/elantra
- Random Parts
- Clock Fix?
- 2001 Tiburon Tail Lamps Not Working
- Thinking about removing the lip
- Tib fluid level
- Cel P0138 & P0141
- Rd1 - Painting Headlight Bezels
- Speedometer
- Where should I put these?
- Dash Clock And Interior Lights
- Ebay
- Beta 2 cover
- Hazard Lights
- Catch Can
- widebody fenders
- Diy For Beta2 Into An Rd2
- What Globes Are Used?
- central locking
- how much faster is a v6 gk tib versus a beta tib with bolt ons?
- I like this kit too
- Interesting rear bumper
- H7 To H4 Conversion
- Noob Needs Help
- Really Confused
- Really Confused
- Airbag Light
- Alternator Help!
- 2008 Tiburon Gt-v6 Cold Air Intake Problem
- Tps Problems With Bbtb
- tiburon tie rod ends
- My Car Is Turning Into A New Volkswagen.
- Driver Window Stuck Open, Will Not Roll-up
- Pistons coatings...necessary
- Changing the horn
- Rock Auto Closout Parts For Tiburons
- Wiper Relay
- are ground control coilovers good?
- anyone who might know..?
- Engine problem
- Different Wiring Harness?
- Lets Talk Frankencar.
- Fuel Economy With/without Wing/spoiler?
- Has Anyone Purchased One Of Those E-bay Performance Chips
- Rd2 Headlight Issues
- Power Windows Issue
- 2.5" Exhaust Piping On Na W/basic Bolt Ons?
- Electrical Problem Not Fuse Related
- Weird Chain Of Events.
- Fuel smell
- What does 'Tuscani' mean?
- Hyundai Coupe
- Cat Issues
- Question About Maf Sensor
- Tiburon Cams
- Unhealthy Idle Please Help!
- No Power
- Fuel Economy Vs. Payoff Time For Any Modification
- Confused On What To Put Some Money Into
- Rice Or Not?
- I Need An Estimate!
- Will I Need To Modify This Front Flex Pipe?
- What Are Available For Our Cars?
- No Lights
- hyper ground terminal kits
- GK Paint Codes
- Fog Lights
- Wth Car You Just Fall Apart @ 147k Miles?!
- Clutch Adjustment/engagement
- what to do, what to do?
- Tiburon Turbo Kits
- Some Problems I've Been Having
- Bulb Base: Rd1
- Exhaust Rear End
- Help With Ext Door Handle Replacement
- Window Regulator Help
- I'm Gonna Try To Rebuild My Alternator
- Hid's Are Very Dim
- coolant bypass mod
- Engine Rebuild Suggestions
- Cruise Control Not Working
- Need Help
- Compact Designs Intakes
- Looking for.....
- Headlights No Worky.
- Synthetic Oil
- My Ideas For Making The Megan Equal Length Header Fit Everything
- Need Oxygen Sensor Wiring Help Asap
- Need Some Feedback On A New Web Site Idea
- Valve Knock
- All Dash Lights Go On And Off
- Rediator Repair? Inlet
- Chilton?
- Car Doesn't Have Spark... Help
- Front Engine Mount
- The (un)official Post Your Exhaust Thread
- Low Headlights Don't Work, Everything Else Is Fine.
- Revision A Tibs
- Rally Tib?
- Anyone know?
- Failed Inspection Update
- Cool Weather = Dead Battery?
- Upgraded Battery Terminals
- Keypad Ignition
- Won't Start :(
- Front End Popping
- Serial ?
- What Annoys You About Your Tib?
- Who Has The Earliest Vin Number
- 1998 Tib Fx Tuning
- Aem Fic Or Pnp Megasquirt Ecu
- Stock Injector Response Time
- Tibby Is Going Under The Knife Soon!
- Beta 2 Ecu Swap?
- Failed Inspection
- Tips
- Nopi Sale Headers.
- Looking For The Information
- Body Parts
- Just One Thing To Another..
- O2 Sensor Double Female Connection...
- Clicky Clicky Not Good Sound.
- Ignition Cutting Out?
- Power Steering Problems. Cant Stop The Noise!
- Tuscani Badges?
- Horn No Worky
- Going Straight Pipe, The Pros And Cons
- For the tib owners....
- P0122 And P0453
- Difference Between 1.8 And 2.0 Cylinder Heads
- Rd2 Electrical Problems
- It's Alive!
