Question About Maf Sensor
Old Jan 14, 2010 | 11:50 AM
JDN902's Avatar
Vehicle: '97 hyundai tiburon fx
Since in my other topic there was sone question as to the direction my maf sensor is in I was just confirming which way it's supposed to go. Is the arrow supposed to point towards the filter or towards the back of the engine bay? I'm in the middle of putting my stock intake back in an just wantto make sure it's 100% correct
Old Jan 14, 2010 | 12:02 PM
Arrow is in the direction of air flow, so pointing away from the filter.
It should say that on the MAF itself i thought.
....i think
Old Jan 14, 2010 | 12:13 PM
JDN902's Avatar
Excellent tHank you I checked on the maf but didn't see it I had it installed correctly anyway so I can rule that out.just waiting for my ecu to reset then I'll go take it for a drive and see how it works
Old Jan 14, 2010 | 12:18 PM
take the negative cable off the battery terminal, tap the brakes to drain any energy, and that should reset the ECU. No waiting necessary.
If your clock resets, your ECU probably reset.
