- About To Purchase Motoria
- Ngk Wires
- Information On Airbags And Crumple Zones
- Tiburon Motors
- Uneven Wear On Spark Plugs
- Alternator Problems
- O2 Sensors
- Exhaust Vid.
- Oem Water Temp Gauge
- Few Problems...
- Engine Turning Off, Car Idle's Funny
- Safc2
- Lucas Injector Cleaner
- Battery Question
- Over Heating
- Fuel Question
- Walbro Fuel Pump
- Added To Intake..what Do Ya Think?
- I'm An Idiot Help Qquickly.
- Radiator Cooling ( A/c ) Fan Motor
- Aftermarkert Injectors
- Can Someone Help Me Find A Cat..
- Would You Be Willing To Pay For Test/dyno Results?
- What's A Surbo?
- Just Installed My Aem Cai, 4-2-1 Headers, Mbrp
- Impressions: Apexi Cb + 17 In Rims + Short Shifter
- Got Airram Installed
- Tigerlily Bbtb Problems
- Cf Intake...any Interest In These?
- Gauges Question
- Post Up Your Latest Mod!
- Exhaust Questions
- My Exhaust Is In!
- Cam Gears
- My Dealings With Supertech, Ca
- Front Lights
- Natural Gas Equipment
- Power Windows?
- Headers
- Need Flex Pipe Help.
- Need New Fuel Injector ....help
- Oil Pan Patch
- What Should I Do, 97~99 Differences?
- Need Advice
- Evap Canister!?
- Airrams On 1.8?
- My Times..0-60...in 17 Seconds! Wtf?
- Question About Seats
- Wtf!?!?!?!?!?!?!11!?!
- Winshield Spray
- Inazma Plug Wires
- Umm Bad Alternator?
- Need Some Pre Gapped Sparkys
- 2 Hours At Dealership For No Damn Reason
- Motoria Exhaust Question.
- Headlight Problem
- Bbtb
- Break Booster Line
- Quick Question
- Help Me!!...turn Signals
- New Parts
- Fuel Pressure Regulator??
- Shell Vpower - Worth It?
- A Quick Question
- Adjusting Idle
- Ngk Spark Plugs
- Tb Throws A Cel..?
- Air Intake Help Needed?
- Twin Engine Tibby
- Fans
- Switch To Synthetic..
- Ultra Oil Filter +5 Hp? Wtf!!!
- Air Bag Light
- What Size Cat To Get?
- Aftermarket Odometers..
- Auto Rx...looks Good?
- Sr N/a Mod Order
- Bov Sound On N/a
- Did Some Stuff
- Oil Catch, Power Steering And Coolant
- Latest Mod
- Overdrive Question
- What To Do Next
- K&n 57i Kit
- Aluminum Oil Pan
- Installed Aem Uego....
- N/a Items
- Help: Window Washer Doesn't Work
- After An Auto Manual Swap..
- Newb Needs Interior Lighting Help....
- Quick Simple Question..
- Head Cover Set
- How To Install A Starter?
- O2 Sensor & Air/fuel Gauge
- Beta Block
- Lightweight Battery
- Racing
- Ram Air Hood??
- N/a Performance
- Automatic Light
- Electrical Problems...
- Optima Batteries
- Cold Air Intake Fitment
- Creeking Noise
- Got A Couple Questions
- Working On Tibby
- Fitment Of Rside 4-2-1's
- Performance Or Looks?????
- What Now?
- Pulleys..
- Ecu Location
- What Is The Benefit Of Oil Catch Cans?
- How To Get 33 Mpgs. My Answer Inside.
- Catch Can Questions...
- Argh! Wiring Problem. Rear Tail.
- 65mm Or 58
- How Find The 12v "always Hot" In The Rear?
- Who's Heard Of Motorkote?
- Leaking Brake Fluid
- Tibby Maintenance
- Korean Site For Products
- Upgrading Cai
- Ebay Header/exhaust
- Wierd Question, 2nd Cat Heat Shield Neccesary?
- Airram Compatible Strut-brace?
- Engine Hesitation
- Interesting Journalism Facts
- Rpm For Best Fuel Consumption
- C02 Injection?
- Wont Start
- Ceramic Coating Alternative?
- O2 Sensor Questions! Help!
- Water Cooled Turbo Question
- Muffler Talk...
- Dynomax Thrush Glasspck Installed
- Hydrolocked
- Aem Uego Install ?
- Motoria Exhaust
- My Exhaust
- Fabricating My Own Strut Bars
- Which Size/brand Cat - Gt Headers+apexi?
- Getting Rid Of A/c "stink"
- Aem Intake Installed
- Pistion/rods/spring/retainer
- Custom 70mm Bbtb!!
- Trimming Splashguard For Cai..
- Air Problem .. Cai Related
- Headers
- Cai Problem..help!
- Ark Short Shifter
- Exhaust Manifold Recall
- Gas Cap
- Timing
- Mini Nos Kit..
- Silencer
- O2 Sensor Schematic
- Guess Me A 0-60 Time
- Fuel Consumption
- Help! My Speedo's On Crack!
- How Much Hp Will I Get
- Powerchip Update
- Bp Gas
- My Exhaust Setup -suggestions?
- Exhaust Noise
- Sunroof Rattle
- Fuel Pump Help
- Cai Warning
- Just Installed The Aem. My Thoughts.
- Rd2 Dual Exhaust
- Zerodegrees Stage2 Performance Chip
- Ac Not Working...and It's Hot
- Lol Found This On Ebay
- A Couple Of Questions
- AEM Debate
- How To Change Projector In Headlight?
- Blowing From The Door
- Speed Odmeter/ Airbag Light
- 15.8 Volts Normal???
- Requesting Informations About Injectors
- When To Get An Ecu?
- Www.myservicepage.com
- How's This Seem?
- Cel, Sucking
- Cai Problem
- Exhaust Help
- Amazed With Tibbys Performance
- Aem Cai
- Cai Help
- Hyundai Hp Engine Kits
- Fs: Headwork
- Airram Without Bbtb
- I/h/e Question
- Air Bag Light
- Coating Cai
- Loud Noise Coming From Exhaust
- Why Does This Keep Happening To Me?
- Window Switch Problems
- Ngk Wires
- What Next?
- Changing Fuel Filter
- Power Boost
- Just Won An Airram Im On Ebay...easy To Install?
- Header Install?
- Oil Catch Tank
- Need A Good Exhaust
- Dash Lights And Wiring Diagram
- I Need A High Output Alternator
- Best Fuel Additive For A 100k Tibby?
- Ngk Spark Plug Wire Resistance
- Ebay Cai
- 1.8 Ecu Swap
- Help!!!!!
- Ecu Location
- Installed Safc2, Cannot Get Rpms To Display.
- Returnless Fuel System
- Daily Driver Or Not?
- Twin Engine 630hp Hyundai
- Rust On Hood Edge
- Anyone Ever Hear Of Them?
- What Is This Hook For?
- Question For You Wiring Experts
- Natural Gas
- Have A Few Problems...
- Which Cai To Get
- Running Light
- Purpose Of These (on The Side Mounts)
- Poly Exhaust Mounts
- Fixed My Problem...
- Xs Power? Krd? Exhaust+headers
- Iat Resistor
- K&n X-stream
- Steering Wheel
- Latest Cai Mod
- Headers...
- Glasspack
- Catback
- Ark Catback
- Catback
- Some Thoughts
- Fuel Tank Q
- Aem Cai
- Short Shifter
- What Does Cel P1586 Mean?
- 1.8 Im On A 2.0???
- Performance Suggestions?
- Radiator Cap Question
- Flush Or Not?
- What Oil To Choose?
- Did My First "mod"
- Question About Cai.
