After An Auto Manual Swap..
Old Jul 21, 2005 | 09:43 PM
zoned019's Avatar
Vehicle: 97 Tib
After an automatic -> manual swap what is needed to make the cruise still work? Something needs to be done to the driveshaft to read RPMs right?
or what, i'm confused..
Old Jul 21, 2005 | 10:09 PM
gotspeed13's Avatar
Vehicle: 1998 Hyundai Tiburon
I wish I could help you on that. I've been trying to figure that out myself for over a year now. Even asked twice on here.
Old Jul 21, 2005 | 11:53 PM
Did you guys check Webtech?
Old Jul 22, 2005 | 10:00 AM
zoned019's Avatar
Vehicle: 97 Tib
Nothing on webtech except for information on AUTOMATICS, and schematics .. but all of the electrical is there, so those don't really help. Yes the TB cable is connected to the pulley, etc. I don't know what else is needed to make the cruise work, obviously the engine needs to read the gear and RPMs right? I've heard of aftermarket cruise systems being something like a magnet on the drive shaft?
Old Jul 22, 2005 | 11:58 AM
Jaws021's Avatar
i believe its all electronic
Just make sure you have the control unit, the vacuum hose, and the secondary throttle cable, as well as having the harness hooked up
Old Jul 22, 2005 | 12:21 PM
turbotiburon's Avatar
Vehicle: 2001 tiburon/2000 tiburon
oh man did you buy that car from new jeresey then? I never heard of the cruise runnin of off drive shafts..I think its all eletronic and vacum..
Old Jul 22, 2005 | 01:39 PM
gotspeed13's Avatar
I've gone through all of this. Replaced the cruise unit and vacuum pump under the hood. Tested the ohms and continuity at all of the plugs and switches. Still haven't figured why it won't work. Good luck to you and I hope you figure it out because I miss my cruise control. sad.gif sad.gif
Old Jul 22, 2005 | 02:31 PM
zoned019's Avatar
Vehicle: 97 Tib
<div class='quotetop'>QUOTE (gotspeed13 @ Jul 22 2005, 07:39 PM)</div><div class='quotemain'>I've gone through all of this. Replaced the cruise unit and vacuum pump under the hood. Tested the ohms and continuity at all of the plugs and switches. Still haven't figured why it won't work. Good luck to you and I hope you figure it out because I miss my cruise control. sad.gif sad.gif
^^. Haven't tested the ohms and stuff, but everything is hooked up right and cables are tight etc
Old Jul 22, 2005 | 02:59 PM
Jaws021's Avatar
where is the cruise control vacuum hose connected?
From what i remember.. the auto to manual swap should not affect the cruise control
Old Jul 22, 2005 | 05:17 PM
zoned019's Avatar
Vehicle: 97 Tib
but being that the throttle cables and all the electrical things are there, the only thing left that could be bad are the vacuum hose(s?) and the unit itself (i doubt either of these just randomly went..)
So, how does the cruise read the engine's RPM's? for example your going up a hill, the cruise wil accelerate to keep you at the same speed, if I were to guess, THAT is the problem..because automatics have the OD gear whereas manuals have 5th? so the ratios may be different? (ie, 4000rpm in 5th in a manual is a different speed than 4000 rpm in OD in an auto), and the cruise needs those numbers to adjust your speed.
