Airram Without Bbtb
Old Jun 1, 2005 | 02:37 PM
mb1604's Avatar
ok my car's going in the shop next week or the week after for some work. i have my airram sitting here with still no bbtb(waiting on rick) should i get it installed then or wait until my bbtb comes? how much power will i be losing if i just use the airram without the bbtb vs airram with bbtb?
Old Jun 1, 2005 | 02:39 PM
wattsup4800's Avatar
get it installed that airram will still kick ass, the TB is an easy install, youll be fine
Old Jun 1, 2005 | 02:41 PM
hamhead's Avatar
Air-ram without BBTB, you probably won't see much gains without having the rest of the intake system done before it (CAI, TB)... also you won't see all the gains from it until you get some better camshafts. Its not really designed to benefit mild setups, its more of a power item since it has a fairly large plenum among other things.
Another thing to note, you'll save on installation charges putting them both in at once.
Zman's Avatar
If your car will be stopped anyway, put the AirRam in, it's installation is much more complicated than the TB, so you will have 80% of the battle won; on the other side, you won't loose even 1HP, actually you don't loose anything, you gain less HP, which is much different. Just put it on, the sound only will be an absolut compensation for having it there.
Old Jun 1, 2005 | 03:01 PM
Once you put the TB youll see more hp gains and Top End.
Old Jun 1, 2005 | 05:28 PM
col96fx's Avatar
Vehicle: Hyosung GT650
I would def put the Airram on and then fit the TB when you get it.
Old Jun 1, 2005 | 06:16 PM
zoned019's Avatar
Vehicle: 97 Tib
ham do you mean that you won't feel many gains from the airram unless you have hi-cams? what degree? what is the highest degree you could use without a piggyback? the gains of this?
on topic:
i think you should just get the airram put on, the TB is an easy install you can DIY later on (when i installed it it was easier than installing the cai imo)
Old Jun 1, 2005 | 07:11 PM
CyberShark's Avatar
Trust me, you don't need cams to feel the difference the AirRam gives you.
Old Jun 1, 2005 | 07:17 PM
mb1604's Avatar
well im ordering the 1.8 cam. to help with performance. from what i heard it helps quite a bit
Old Jun 1, 2005 | 07:34 PM
zoned019's Avatar
Vehicle: 97 Tib
really? from what I heard the gains are very subtle from the 1.8 cam. I was going to buy blue dragon's, but tibminn beat me to it, and he said that when he got it installed there was only a slight difference.
