Help Me!!...turn Signals
Old Aug 2, 2005 | 09:38 AM
mindlessdoubt's Avatar
Yesturday I took my dash apart and I took the guage cluster out to put some overlays in...well I did it and got everything put back together...cept I blew a fuse doing it...so...this morning my battery was dead so I hot shoted it and let it run for 5-10 minutes..and I was on my way...then I realized my turn signals don't work inside...so when I got back home from buying fuses...I checked the outside lenses and they didn't work either... but last night after I blew the fuse they did work...anyone have any thoughts?
(if this isn't the right place to post it, then move it accordingly)
Old Aug 2, 2005 | 09:43 AM
JonGTR's Avatar
You're probably blowing the same fuse again. There's a short somewhere. You might have pinched a wire or something.
Old Aug 2, 2005 | 09:46 AM
oh...and I rechecked all the fuses that I thought might something to do with it...like the hazards and tail lights...actually I think I pulled every fuse in both places...any idea how much it might cost to get fixed if it is a short?
Old Aug 2, 2005 | 09:50 AM
JonGTR's Avatar
If you had enough skill to tear apart the dash, then you should know how to trace the path of the signal's to its short.
Old Aug 2, 2005 | 09:57 AM
How do I go about fixing this? Cause I havn't done anything like this before...like what does it look like if it is a short and so forth?...sorry I'm not the most advanced person when it comes to cars/electrical work
Old Aug 2, 2005 | 10:00 AM
homey14h's Avatar
look for bare wires touching, or a wire touching something else that it shouldnt be, you could always take the dash apart then turn the car on and see if you see a spark
Old Aug 2, 2005 | 10:03 AM
JonGTR's Avatar
Just follow the path of the wire from the fuse box. Make sure it doesn't have any tears, pinching, or touching any bare metal.
Old Aug 2, 2005 | 10:54 AM
I couldn't find anything...anyone have anymore suggestions...if not, I'm just take it up to the shop tomorrow...02.gif
Old Aug 2, 2005 | 01:28 PM
Moving this to general performance:
What else did you unplug? I would definatly check and make sure that all the connectors are tight, especially around the four way flasher.
Old Aug 2, 2005 | 11:18 PM
I checked everything...I'm going to the shop tomorrow to have them look at it...thanks to everyone that helped me though...I'll post back with what the problem is
