Cam Gears
Old Aug 10, 2005 | 01:06 PM
matmag89's Avatar
I was just wondering, If I put a cam gear on my tib will it screw with my E.C.U.?
Thanks
Old Aug 10, 2005 | 01:22 PM
mb1604's Avatar
ummm i dont think it would but you have to go to a dyno shop to tune the gears.
Old Aug 10, 2005 | 01:31 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
It shouldn't screw with ECU.
But for best results you should tune also ignition timing.
Old Aug 10, 2005 | 03:07 PM
Zman's Avatar
Cam Gears become necessary when you change into agressive cams, and that's because you can tune where in the rpm range you want tho most power, you can tune it for highest power, or you can sacrifice a little top end power for more torque at mid-range (unless you are a full race driver, the last option would be wiser).
I don't know if you really get more power with the cam gears, I just think you move the power band with them, but if you want to try go ahead and keep us posted.
