Cel, Sucking
I have a cel and took it to auto zone after doing the gas cap and everything, it came up as a leak in the intake or exhaust, a small one, I was checking it and while there is a sucking sound comming from behind the IM, is this normal or should I keep trying to use double sided tape on all the line connections, I cant hear exactly which line its comming from because of the engine noise
It went off after I played with the lines tightning the clamps and putting double sided tape on some connections, it went off so I stopped messing with it to find exactly what it was
I use double sided tape on the exhaust and in the engine bay, it works fine, I used it to clog up where the hoses r on the conectors, and tightened them if I could, I took off the doublesided tape where I could see it and the CEL stayed off smile.gif
Ive only had a CEL on once before more than a year ago, restarted the engine and it went off, for the exhaust I can use it for some viberations around the muffler area
