- mods that make car sound great???(tiburon)
- Clear up 1.8L and 2.0L Beta differences
- My Random Special CAI
- Hydraulic engine mounts 2000 Tib
- Hyundai Beta Crank Trigger ?
- Tib Cams
- who has shots of 03tibgtv6 cat back?
- Sonata cams and the V6 Tib
- low-mid 14s in a 00' Tibby???
- 97 tiburon custom cai installed
- Bulletproofing a Beta Motor.
- Tiburon Owners Rejoice.
- 2.0 Beta Intake Manifold
- Anybody from Maryland have headers on their Tib?
- Runs, but chokes out (not a Tibby)
- Tiburon Alternator Upgrade??
- turbo manifold?
- Beta Pistons?
- Neo_tib: Please read
- Help...Grinding Second Gear
- 2003 Tib dyno results
- Random: Elantra and Tibby pieces compatible?
- New 03 Tib 5 speed
- what's the best year tiburon to do up?
- Exhausts for Tibbies
- Delta V6 Headers, catback, strut bars & stuff
- Gen3 V6 Delta RS-CAI Pics (Safe for 56K users)
- Anyone make an Intake for 03 Tiburon V6?
- 2000 tiburon mods
- 2003 Tiburon Power
- 2003 Tiburon Intake????
- 2.0 l BETA Engine Block
- 2001 Tiburon 0-60 stock?
- 2003 tiburon
- 03 tib
- Topped out at 130.....need more...please help
- '03 Tiburon, Ques about your exhaust.
- need best intake for tiburon
- Are the new Betas MAP in the US?
- Gen3 V6 Delta Info...
- tib sound clips
- 1997 Tibby short Ram cold air intake
- AEM Intake for '03 V6 Tib
- SR headers with 97 rev A tib
- Random I need your brain power!
- beta engine head metallic nervature
- beta block: how many oil?
- question about a part on the IM for Tib
- 2k3 TIBS Question
- how to get n/a power in 1.6 BETA?
- SR CAI for MAP based Betas
- cams for 2001 tib
- tib got her cherry popped today!
- 2.7 Delta Engine Aluminum Flywheel
- 2003 Tiburon 0-60 times?
- 03 Tib Engine Questions
- 2003 BETA Exhaust
- What's out for 03' Tib
- 1.6 Beta question
- 01 Tib Spark Plug gap
- top recorded horse power for a 2.0 beta engine?
- performance chip for 2000 tibby
- dual exhaust on 2001 ?
- porting stock beta manifold
- tiburon exhaust system
- Beta Engine
- Once again I need help
- dragon fabrications twin engine tiburon
- For those who's tibs make a gurgling sound....
- Maximum Bore Beta
- Which intake/catback?
- Aussie Beta Owners
- anyone tuned 1.6 Betas before?
- Spark Plugs and the 2k3 Tib
- NOS AND the 2k3 Tibby Fuel Pump
- HDK Aluminum Flywheel
- computer chip for tib
- Tiburon Engine
- Do '97 Tiburons have 2 O2 sensors?
- Dyno question
- HIGH FLOW CAT GROUP BUY
- 1.8L intake cam is IN!
- Help with Exhaust.
- What are the views, unbiased, of the AEM Tiburon CAI
- Fuel Ratio
- What size inlet on a 2001 Tibby???
- Arospeed Tunable Bomb Muffler on a Tiburon
- Need to find a full Tiburon Exhaust system
- 10 second tiburon
- Cold air intake for automatic Tiburon!!!! I need one!!!
- Automatic Tiburon Is OK... Isnt it?
- Tiburon Cuda kit Exhaust system
- 0-60
- BETA engine available in the "For Sale" section
- Acura Integra Low Compression Pistons can be swap to our tibs !
- Used Beta Motor
- 6 speed/ V6 package
- Is Engine in Tiburon suppose to move?
- Power Chip
- Would there be anyone willing to buy a fully built Tib motor?
- CAPA Dual Throttle for Beta Engine?
- When you remove battery from 2K1 Tibby...
- i just ordered forged pistons and chromoley rods
- Ok so for real this time: The *actual* specs of the 1.6L Beta...
- Here's your 1.6 beta
- OK Red I am calling you to see the 1.6ltr BETA
- MSD Ignition System for Tibs ??????????
- 99 Tiburon FX part recall
- MBRP Exhaust Group Buy for 97-01 Tiburons!!!
- Tiburon Rally Cars
- chip for 2k tibs
- White CAI for Gen1 Tibbys?!
- Does CAI make your exhaust louder?
- Anyone knows if the 97 tib exhaust differ from the 99?
- Level 10 Rocks!!! Any automatic tib owners look Here
- Exhaust for a Tib
- How fast are stock tiburons?
- Hey Random, specs on that 2G Beta intake cam?
- Cat Back exhaust for 1st gen tib
- QÜIKTIB custom CAI intalled
- Is your dealership THIS cool? Pictures of the 2G Beta head...
- Bosch Spark Plug for 2001 Tiburon?
- 2nd Gen Betas
- Revision A Tibs -- Moving that Evap Cannister
- Ecu Chips for tiburons???
- What Beta's are made of Part II
- What Beta's are made of.
- 2000 tib cold air intake
- Shift Kit and stall Converter for 99 Automatic Tib
- 2002 Tiburon Engine
- Rally spec tib engines
- Spec A Tiburon Differances?
- 2001 Tib...increase horse/rpm¿¿¿
- Where can I find an Cold Air Intake for my Tibby
- v6 pistons in a 4 cycl.
- Korean N/A Tibs????
- K&N CAI
- Quad-throttle body setup
- Venom ecu
- Super Matrix Breather
- fuel filter
- What's is the cheapest way to put up the horse power for my 2000 Tiburon???!!!!
- Where can I get ported and polished heads Random, someone help!!!!!!!!!!!!!!!!!
- IGNITION SYSTEM
