2003 Tib dyno results
Old May 19, 2002 | 03:15 AM
whenharry's Avatar
Default 2003 Tib dyno results
Greetings all,
I've been testing the 2003 GS-R for the past week (I own a 2001 Tib) and I got the results from the dyno back. You can check out some shots and the results here:
www.yuilllog.com/tiburon
Cheers,
m@
Old May 19, 2002 | 04:27 AM
Mach5's Avatar
now i really can't wait to get this car...
Old May 19, 2002 | 10:30 AM
Suprgtrs_man's Avatar
Good work but the average drivetrain loss on a 5spd FWD car is about 15%, not 12.5%. Your 117 whp is a little low. Normally the 2.0L Beta Tibs/Elantras do 122-128whp. Your 17" wheels can take 3 or so HP away from the dyno so you are only a few hp short. Your dyno looks a little jagged also, you may have been breaking traction a little. Keep up the good work.
Old May 19, 2002 | 12:07 PM
goodness. bigger rims need not rob power. They can actually help if they are lighter. Not all big rims are heavy.
Old May 20, 2002 | 12:29 AM
AfterShocK's Avatar
<div class='quotetop'>QUOTE</div><div class='quotemain'>Suprgtrs_man:
Good work but the average drivetrain loss on a 5spd FWD car is about 15%, not 12.5%. Your 117 whp is a little low. Normally the 2.0L Beta Tibs/Elantras do 122-128whp. Your 17" wheels can take 3 or so HP away from the dyno so you are only a few hp short. Your dyno looks a little jagged also, you may have been breaking traction a little. Keep up the good work.</div>Well this could be because of the dynojet he was on.Maybe the sea level also. I've heard each one can register different then the others.
on the other hand though, your 2k3 is putting down the power. The thing I don't understand about Hyundai is why do they die after like 5500-6000rpms, instead of at the redline.
Old May 21, 2002 | 05:26 AM
Reid's Avatar
Most cars will die before redline. You keep the rev limiter a tad higher so that when you up shift, your rpms will be closer to or in the power band in the next gear.
Old May 21, 2002 | 05:29 AM
Reid's Avatar
The jagged dyno is where they shifted to the next gear...last year when we dyno'd our cars (GS72ES from Fxtreme and myself), we did one run to see what the top speed of the 2k Tib was, and his chart looked like that during gear changes.
Our cars topped out at 142mph.
Old May 21, 2002 | 08:51 AM
Yeah I guess I should have clarified about the weight of the rims but I didn't see volks or Advans on his Tib. I was talking about the power graph. Most dynoes are not that jagged. his is a little rough, not much but a little more than I usually see.
Old May 22, 2002 | 05:12 AM
Koreandude's Avatar
Your 117 whp is a little low. Normally the 2.0L Beta Tibs/Elantras do 122-128whp. </div>Hey Man, you might want to recheck those numbers again. I've seen way too many dyno charts from 2.0's and 1.8's including my own not to know what they ave. (about 105-108 and about 95 respectivley) Besides, RANDOM posted some dyno results including a Tib 2.0l with intake/header/exhaust/etc. pushing about 125 i think. yes there is a general rule about drivetrain losses but that's just as accurate as those silly Hp calculators every car jocky has on their web site. They give you a fairly good IDEA, but the DON'T state the FACTS. People should stop guessing and just get their cars dyno'd.. end of story. wink
Rich.
Old May 22, 2002 | 05:14 AM
yamaneko's Avatar
Yes, 115-120 is what a stock 2.0 does.
