View Full Version : Hyundai Tiburon Forum
Pages :
1
2]
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
- Car took forever to start this morning!
- dead cluster and climate control lights
- Replaced my TPS, now Idle is worse
- Weapon R Torque Damper
- Is there a way to raise the rev limiter?
- head bolt torque pattern
- Tein Super Street Coilovers
- Bodykits Available
- HID's on a 2001 Tiburon
- Is this a good deal?
- Never knew Altezza lights were KDM
- Instrument cluster bulbs
- Genesis diffuser on a Tib
- Tiburon won't start with low gas tank
- Keeping water spots out of cupholder
- looking for lenses,00 tiburon
- problem finding o2 sensor pin on ecu harness
- Limits of the stock suspension
- 08-10 Tiburon body code
- wish i could find a set of these fenders in good condition
- RD's on dealer lots
- Smoking a bluish gray color from exhaust
- Intake Manifold headers
- Finding the leak
- exterior parts
- Best way to clean salt from undercarriage
- new member needs help! - idler / O2 codes
- Wet Floorboards
- 01 Tib rocks when A/C compressor kicks on
- Swapping doors
- Major problem with gk!!!
- Getting started, recommendations?
- Tiburon feels like half power
- '97 RD Hazard Switch Electrical Wiring Diagram
- People still cut their springs
- Engine Wiring Harness
- Never seen these tail lights before
- Tuner/programmer options?
- Soo...... Turns out I'm in the market for a cat-back
- rear brakes freezing?
- O2 Sensor Wire Split
- Best N/A mod that yields the most power
- Sagging rear Eibachs
- Holy Rust!
- www.turbotiburons.com
- Gearbox difference rd1 vs rd2
- Need Wiring Help
- OEM Fog light alternative replacement?
- Wow this is hot!
- Hella Supertones
- About that radiator swap.....
- Guess some people still do the F&F graphic style
- Picture Request
- Heater / A/C is clicking loudly
- Did people try to convince you not to buy your Tib?
- Poly Engine mounts
- After some deep consideration...
- GK vs. RD1
- Power locks
- 2001 Tib passenger marker lens/assembly
- High idle when IAC is plugged in
- Lowering a Tib, need to sheer the tie rod?
- Tuscani badges
- Fender Roll and Pull
- RD section
- Tiburon turbo upgrade
- Burning and blowing Oil
- Hit the curb
- How do I get a manual for my Tiburon? Besides dealer.
- Am I the only one that thinks the Tiburon could have been "more"?
- Not enough vents
- Lower cross bar bolt stripped?
- Low Fuel Light?
- Thinking about taking off my Veilside kit
- Issues with cruise control
- Is the sunken in look better than hellaflush?
- Wheel Stud Part Number
- Replacing stock stereo
- Needs Moar Gauges
- Oil Cooler Position in Relation to Filter Debate
- What happened to Long?
- exhaust
- Time for a new battery
- Walrus Tib
- wheel spacers
- Help me decide my next suspension setup
- Tiburon weight
- Suspension squeaks
- Fuel delivery problem?
- P1127 1.8L cam and ECU
- A SUPER DETAILING FIND
- Door panels missing screws
- Affordable Battery Impact Gun/Drill that can handle lug nuts
- strut bars and way bars
- How many clay bars are needed for a tiburon?
- Squeaking?
- Name all the things you see wrong with this Tiburon
- GKs ARE EVERYWHERE NOW!
- A/C bypass
- Did RDs ever come with a premium sound system?
- Rotor options?
- Help! No spark!?
- Magnaflow catalytic converter - 23263 VS 50223
- Kenwood eXcelon - any good?
- Pic request: Black with polished lip
- Jet Performance Chip #65002
- Lug thread size
- anyone tired of seeing LED STRIPS
- Suicide doors > Lambo doors
- Evolution
- SMT6
- High beam projectors
- You know you're a 2nd genner when....
- You know you're a 1st genner when....
- removing valve / rocker cover
- Hyundai Factory front strut bar
- Car won't start
- Coupe or Convertible?
- Studie Kit
- Advantages to removing power steering
- A/C turns off at 240 degree coolant temp???
- Anybody on here?
- Adjustable sway bar end links
- Do I need to claybar?
- Search For Parts
- Best. Bodykit. Ever.
- Is this in a video game?
- 03-08 Tiburon Front Big Brake Upgrade
- Tightening the ball joint nut
- my poor girl just sits now
- Tried to change out the roll post motor mounts
- Problem with short shifter install
- Beautiful set up
- Turbo Charged
- Megasquirt II Extra on a 97 Tiburon
- Do these spark plugs look okay?
- 01 Tiburon , what transmission do I have?
- Generation Splits
- Look at this paint job
- Oil Filter for 2001 Hyundai Tiburon?
- What's the oldest working battery you have?
- Help i need Last 8 numbers of vin number for tiburon
- Clean out the evap canister?
- Whats the parking authority like where you live?
- Beta 2 Engine Swap in RD
- Anybody know what body kit this is?
- 2 tone paint jobs
- What do you think of this Tiburon?
- Applying tint over dot matrix
- Lip Molding
- Really cheap coil overs for GK's
- need a fender and a timing belt
- Oil Leak
- Go home GK, you're drunk
- Uk hyundai Coupe Cup
- If you dont know where this pic is from, then you aint old school
- Worst bodykit ever
- Help!
- Best Headlight bulb replacement ?
- 2002 Accent key transponder pickup fit Coupe ?
- A couple of Questions
- Foreign Options
- Glass polishing
- Targa Top
- I see your GK bumper and raise you a Mitsubishi bumper
- I always wished I had this color tib
- Got my Sniper wing
- 2011 Sonata antenna replacement
- Ricer Ricer Ricer Ricer
- Wiring mids to an amp
- Need an Engine
- Gauge Overlays
- Tiburon Myths
- What is the lowest recorded RD on this site?
- If you had your wish and your car could be ANY color, what would you choose?
- 2001 Tiburon
- Car getting bad MPG / Smells like gas on startup
- How hard is it replacing quarter panels?
- Lower arms?
- GK bumper on an RD
- How do I tape off reverse light for Nightshading?
- Anybody ever heard of this stuff?
- ABS and Brake Warning Lights 2002 Tiburon 2.7 V6
- Rewired Beta. Small Spark Then No spark.
- confused about 3 pins on Tib ECU
- Leaning out
- Favorite body kit
- Speed Differences
- 2.0 Tiburon OBX Exhaust
- Power distributer block
- Turbosocks kits
- 4 cyl. to a v6
- Catch up..
- The tiburon will be 16 years old this year
- Die hard
- Timing belt play specification?
- headlight shake
- What's the difference?
- Do you still love your RD?
- For those of you with scratches, do you fix it or wait to accumulate more?
- Quick Link To EVAP Canister Delete. HP.COM
- Braking Issues
- Cruise control stopped working!
- What rake style do you like best? Positive, Neutral, or Negative?
- Need a new front bumper..
- Where do I find this part?
- I cant decide if I like this or not
- The Great Tibby Adventure
- Anyone ever scraped their exhaust?
- performance chip
- cold air intake
- Why, hello there!
- Offsets and bearing effect?
- How do you take care of suede seats?
- Fuel pump
- Where are the Ignition timming marks ( Ignition timing )
- Remember Sarah? Her tib is featured on KDM Stance
- Thinking about boosting
- wanted Tiburon bumper question
- Brake Cooling Question
- Does your hood still have the insulation pad?
- my brakes "chirp"
- power steering max psi
- Cordless buffer/polisher
- More rare 1.6L leather seats
- LSD options for RD Tiburon
- A bad place to park
- Race stripes
- Timing belt whine
- Auto-dimming mirror, HomeLink for RD1?
- Did anyone ever buy this?
- How good are these throttle bodies?
- Idle jumping from 1500-2000 rpm
- Does anyone have these on their tib?
- New Tiburon Owner
- rough idle, steering slip/squeal?
- Trade coil pack for parts
- Clear Bras
- Free Rd Tiburon Header
- If you sold your car to someone else
- What tires fo you use on your Tib?
- Winter is coming - heated mirror question
- How Should I Go About Adjusting Stereo EQ?
- Electrcial Problem, help please.
- IAC valve buzz?
- Lightweight or underdive? and brand?
- Check your transmission fluid!
- Figuring out Ignition Timing
- power steering fluid type?
- Car shudders when I lift up on the clutch
