2011 Sonata antenna replacement
Vehicle: 2011/Hyundai/Sonata
I broke the top of my plastic antenna off by back out of the garage before the door was completely up. I bought a new antenna assembly. How do I replace the antenna? I'm afraid to damage the headliner.
Thanks, Brian
Thanks, Brian
Vehicle: 1991 Impulse RS
like I said on the other site.
https://www.hyundaitechinfo.com/
login - rdtiburon.com
password - tiburon
you'll find all the info there, as well as the shop manual. You're gonna have to do some searching on the site but it shouldn't be hard to find.
password - tiburon
Thanks for your help. I have tried for about 3 hours to determine how to remove interior roof trim/antenna. I copied the words without the schematics. What I found does not help much:
Roof Trim Replacement
• Put on gloves to protect your hands.
• When prying with a flat-tip screwdriver, wrap it with protective tape to prevent damage.
• Take care not to bend or scratch the trim and panels.
1. Remove the following items :
A. Rear seat cushion
(Refer to the BD group - "Rear Seat")
B. Front door scuff trim & Rear door scuff trim
(Refer to the BD group - "Interior Trim")
C. Front pillar trim
D. Center pillar lower trim & Center pillar upper trim
E. Rear pillar trim
F. Sunvisor
G. Overhead console
H. Room lamp
I. Assist handle
2. Disconnect the connector (A).
[Driver's]
[Passenger's]
3. Disconnect the clips.
4. Remove the roof trim (A).
5. Installation is the reverse of removal.
Component Location
1. Audio unit
2. Midrange speaker
3. External amplifier
4. Glass antenna (AM/FM)
5. Front door speaker
6. Rear door speaker 7. Woofer speaker
8. Antenna feeder cable
9. Feeder cable joint connector
10. Audio monitor (For PA760)
11. Multimedia jack
12. Roof antenna (SDARS)
E. Rear pillar trim
F. Sunvisor
G. Overhead console
H. Room lamp
I. Assist handle
[Driver's]
[Passenger's]
Component Location
1. Audio unit
2. Midrange speaker
11. Multimedia jack
