How good are these throttle bodies?
Old Nov 18, 2012 | 01:01 PM
Subculture's Avatar
Vehicle: 2000 Tib
Default How good are these throttle bodies?
http://www.ebay.com/itm/KDM-Hyundai-...-/110658420167
[ebay]110658420167[/ebay]
Would I have to bore out the intake manifold to feel any power increase or will I feel something in the butt dyno with just the TB?
Old Nov 18, 2012 | 02:06 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
I can let you know next spring. Just bought one for my car, but it's suppose to increase throttle response.
For $300 + shipping I think I would try to find a cheaper one.
Old Nov 18, 2012 | 02:09 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
im pretty sure the TB and the manifold are same size.
So you may need to cut away some of the manifold hole to notice a gain.
Old Nov 19, 2012 | 09:22 PM
300D50's Avatar
I'd just get a GM truck tbody, and make an adapter plate.
Or run dual stock tbodies.
Old Nov 20, 2012 | 04:29 PM
red97tib's Avatar
Vehicle: 1997/Hyundai/Tiburon
I thought Tigerlily went under years ago.
Also this throttle body doesn't have cruise. But I don't think there are many options left for BBTB for the Beta motors unless you go custom. I hope somebody tells me of one still being produced that I don't know of.
Old Nov 20, 2012 | 07:37 PM
You're better off just removing the stock TB and IM and sending them out to be port & polished. Cheaper than the Tigerlily, you keep your cruise control, and you'll have better performance.
Old Nov 20, 2012 | 07:51 PM
300D50's Avatar
Anyone with access to basic hand tools can make a throttlebody adapter, it's not rocket science.
If you want alto keep cruise, grab a V6 tbody from a 2000-ish Mitsubishi with the integral cruise actuator and plumb the vac line to it.
Just remember to block off the IAC ports in the replacement tbody.
Old Nov 21, 2012 | 04:26 AM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
For normally aspirated I'd wouldn't waste that sort of money but for forced induction they work a treat
Old Nov 21, 2012 | 06:54 PM
red97tib's Avatar
Random question. How large can the throttle body go if you bore out the intake manifold? I think 70mm will hit the studs that mount the throttle body to the intake manifold.
Old Nov 21, 2012 | 09:18 PM
300D50's Avatar
You can go larger if your adapter transitions from circular to + shaped, and you use a custom gasket or 518 gasket maker.
