Car won't start
Old Jun 20, 2013 | 12:46 PM
capn tibs's Avatar
Vehicle: 2001 Tiburon
Default Car won't start
My 2000 Tiburon won't start and I was hoping you guys could help me out. The RDTiburon group was always helpful in the past and so was Hyundaiaftermarket.
Anyway the problem:
My car doesn't get fuel to the fuel rail or spark when I turn the key. The car somehow will start if I spray starting fluid into the intake. It will run only if the rpm's are held higher than 2k.
So far this is what I have checked or replaced:
I have recently replaced the fuel filter and the fuel pump
I do get fuel to the rail when I run power to the fuel pump test connector
Fuel pump does not turn on when the key is turned to the on position before starting the car
Battery is getting correct voltage
The ground by the battery has been cleaned of paint and rust
Crankshaft position sensor has been replaced with a new one
I have tried another ECM that I have been sitting on that is supposedly good
No matter what I check or do so far the car will not start. It seems like it isn't getting good spark, but with ether it seems to give it that little extra umf that it needs to turn over. Any thoughts or help would be greatly appreciated.
Old Jun 20, 2013 | 05:05 PM
SR Tech's Avatar
Vehicle: 2011 Tuscon
I said crank sensor, saw you changed that already
Are there any codes in either computer?
Is there power at the coils when the key is on?
Old Jun 20, 2013 | 06:04 PM
Check voltage at the fuel pump. Check fuses.
Old Jun 20, 2013 | 06:06 PM
capn tibs's Avatar
Only code is for the o2 sensor. I will have to check if im getting power to the coils. Any tips on where to connect a test light to them?
Old Jun 20, 2013 | 06:07 PM
capn tibs's Avatar
Fuses are all good, relays have been swapped with other known working relays
Old Jun 20, 2013 | 06:13 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
I think you already found the problem. It's not getting fuel, test your pump. Even new pumps can go bad.
Old Jun 20, 2013 | 07:45 PM
capn tibs's Avatar
I checked the fuel pump by running a jump wire to the test connector by the iac and the pump works...its not the fuel pump
Old Jun 20, 2013 | 07:47 PM
capn tibs's Avatar
Even with the fuel pump jumped and running the car does not start because it gets no spark
Old Jun 20, 2013 | 07:49 PM
pas1216's Avatar
If the car starts with starting fluid, the engine is not getting fuel. If the pump is working......
