Check your transmission fluid!
I changed out my tranny fluid with redline MT-90. When I drained it, I only got roughly 1.5 quarts out of it (even after jacking up the passenger side to elevate it). I was able to put in the 2.2 quarts until full. It seems I have a bit of leak coming out of where the axle shaft hooks in to the transmission. Not sure how to fix that though. I guess I'll just be sure to check the fluid every few months. Unless you guys know why it would leak out of where the axle shaft meets the transmission, or how to fix it?
The seals are usually damaged during installation of new cv joints. You can replace the seals for a couple bucks. You will need to remove the drive axles to get to them. It's probably about a one hour job if you haven't done this before. Make sure to be careful with the seals during installation.
3-4 hours to replace the transmission, maybe. 3-4 hours if you detach the knuckle at the top, include driving to the shop, waiting, having an alignment done, driving home, maybe. It's careless axle removal/replacement that damages the seals. Don't insert your prybar too far, don't smash the new seal when replacing the axle
1: Pull axle
2: Pull seal
3: Replace seal
4: Replace axle
edit to add: 5: top off transmission oil!
1: Pull axle
2: Pull seal
3: Replace seal
4: Replace axle
Well I'll see how fast it's leaking out. I'll check the fluid in a few weeks. If it's not leaking that fast I'm not going to worry too much about it. It can't be too big of a leak since there's never any fluid drops on the ground.
buy a presser tool from advanced auto..
its the seal that needs replaced where the CV shaft fits into the transmission, it lost its adhesive properties, most likely.
i use pipe sealant for the transmission seal
or take it to a mechanic but i've heard horror stories on here about them not correctly replacing tranny seals
