View Full Version : Hyundai Tiburon Forum
Pages :
1
2
3
4
5
6
7
8
9]
10
11
12
13
14
15
16
17
- Fuel Guage Needle?
- Idle Screw
- Glass Sunroof Out Of A Newer Tibron Fitting An Older Tiburon?
- Help Me Pass Emissions
- Does A Cai Really Improve Gas Mileage?
- Nice Website Found With 2.4l Theta Info.
- Ticking Noise Finally Found!
- Too Good To Be True.
- Mini Exhaust Question....
- Uhm... Rd1.8
- 1.8 Ecu, Safc-ii, Or Both?
- How Do I Unlock A Seatbelt?
- Cat Or No Cat, That Is The ?
- Electrical Question
- Exhaust Mani Cracked... Recall?
- What Can We Do To Get Ngm Parts?
- 1.8ing My Engine This Weekend And Need Help
- Cel On..
- Window Problem!
- Ecu's
- I Keep Seeing These On Google Images.
- 98 Tib - 21 Mpg
- Looking For Oval Muffler Tip
- Bosch Premium Wire Set
- Comprehensive Aftermarket Mod List
- Lots Of Mileage
- What Next...?
- Exhaust Modification
- Where To Start On My Motor?
- Iat Sensor Question
- Turn Signals Not Working
- Tiburon Vs Mustangs
- Drivers And Passenger Door Wiring Harness Nitemare, I Am So Upset And So Choked About This
- So I Got 380 Miles A Tank...
- Which Engine Set Up Is Best For 400whp?
- Water In Engine?
- Done A Couple Of Things Today And Had A Q Or 2
- Finally Getting My Exhaust
- Header Help!
- My Wideband On The Fritz..
- Fixed My Car Not Starting Problem
- Knifed Crank And Lightened Flywheel?
- P0301
- Went Wrong With My Can
- Fender Liners ... Rd2 = Rd1?
- Anyone Know This Seller?
- E-brake
- Quick Headers Question
- Misfire...still?
- Found A New Korean Site, Thanks To Topspeedfx
- Manual Vs. Automatic
- Will A 1.8 Mas Work With A 2.0
- "ect" And 1.8 Ecu
- Vw Air Pump Installation ! Lol
- Ape Motors Products
- Catback Exhaust Kits That Are Worth A Hoot...
- Alternator Question
- Picture Day
- Hyundai Has A 2.4l 4cyl?
- Ecu Is Stuck!
- Hvac From Redz
- Tps Adaptivity
- Wdymtw? 4 April 2007
- Custom Im
- Cuda 1 Exhaust Help Please!
- Crank Pulley...help!
- Oh Crap, did i buy the wrong axles?
- I'm Just Curious
- Servicing Guide
- Door Lock And Unlock Trouble Shooting Rd2..help
- Regular Vs Mid Grade Gas = 25mpg-> 31mpg-> 25 Mpg
- Shaved Handles/no Inspection
- Comparing Cais
- Just Bought 1.8l Cam
- Exhaust Question
- Need Lots Of Help Asap
- Better Than Oem Injectors? 1.8 Ecu
- Cel's Galore! Help!
- Will This Look Bad
- Bleeding Clutch
- 2006 Hyundia 4cyl (my Car)
- Aftermarket Tails Like The Amazon!
- Gutting The Pre-cat
- Guess What I Got!
- Advice On Clutch, Rusted Bolts And Semi Stripped Caliper Bolt
- Help Me With This Bogging Issue...
- Painting Interior? What Paint?
- What I Need To Complete Kit?
- Electrical Problem
- Engine Codes...i Need Some Help!
- Coolant Additives
- What Does This Error Code Mean?
- Strut Broken?
- Problem With Exterior Lights
- Diff Between Mech And Electronic Gauges?
- Dammith My Stock Tibby
- Alternator Belt/bolt...something?
- Question About Air Sensor Wiring
- Normal Resistence For Spark Plug Wires?
- Has This Ever Happened To Anyone?
- Thottle Body Question?
- Painting Header
- Having A Problem With My Cruise...
- Buying Another Tib Need Advice
- Wdymtw?
- High Idle And One Thing To Check Out
- Need Help Asap
- Passenger Side Door
- How Much Horsepower
- Need Help With Crank Position Sensor
- Hid Kits
- My Exhaust
- Header Wrap
- I Am Looking For Decent Quality Headers....
- Need Help
- Help With Swap
- Wdymtw?
- Quick Help Finding Ignition Wire
- Rd1 Gauge Cluster
- Question Bout Clutch And Shifting
- What's The Connector Right Next To The Cps?
- Centrifuge Oil Filter
- Rd2 Seat Fitment In Rd1
- Safc 2 And Stock Ecu?
- Another Muffler Question
- Crash
- Intake Manifold Bracket
- Poor Alternator Performance
- Hyper Force System For Rd Tiburons.
- Sparco Seat Bracket?
- Apex Exhaust And Flyryde Apex
- Dual Tb's With Dual Intakes.
- Difference Between F And R Cats?
- Difference Between Oxygen Sensors?
- Cel
- Anyone Using Digimoto 4.03
- Ebay "throttle Body Bypass Kit"
- Aftermarket Headers Dilemma ?
- Exhaust Flange Question
- Underdrive Crank Pulley
- From Ceramic coated Airram
- Headlight Bulb ?
- Relay?
- Anyone Know The Stock Fuel Pressure?
- Vin Numbers For Cams, Pistons, Ecu & Headgasket
- intake cams
- Making A Custom Exhaust
- Ebay Audio?
- Opinions On The Bullydog
- General Cruise Control/iac Question
- Quick Sub Question
- Hi Flow Cat Help
- Gauging Intrest In Intake Manifold
- Muffler Tip ..
- Ecu Swap To Map Based
- Seafoam Stuff
- What Exactly The 12.0 To 1 Compression Mean?
- Long Day Working On The Car.
- Ebay Short Shifters
- Need Help With Obdii Scantool Interface **update**
- Stupid Exhaust Question.
- Opinions On Seafoam
- Car Is Shaking With Lights On
- Tib Problem..
- How do i tighten my PS belt?
- To Do List...
- Extra Gasket?
- First Problem(s) Ever...
- At Last She Throws Me A Curve Ball...
- Anyone From Socal?
- Header Question
- Guess I'll Put This Here...
- Throttle Body Bypass
- Whats Up With This, Does It Work?
- Aem Cai Question
- Cel Light
- Tiburon 97
- Maintec Manifold
- Pre Bent Rollbars
- Cel - Po422 - Reduced Cat Efficiency
- Acceleration Pully
- Heater Problems
- Gauge Cluster Problem
- Ark Exhaust?
- Dual Exhaust Layout?
- System Upgrade
- Viper Armed>> Making Me Angry
- Muffler Question..can This Be Right?
- Hey
- Track?
- Just Got An Apex'i N1
- Some Fab Pics
- Crazy 7.11 Sec Tib
- Tach/speedo Ecu Wires
- Searching For Fog Light Wiring
- Sunroof Springs
- Relay Going Behind My Dash.
- Cai Help
- Wire Harness
- Buddy Club Korean Office
- I Reached A Record.
- Auto Windows?
- Master Widnows Switch
- Alpine Turbo 35-80mph Vid
- Heat Wrap.
- Clunking Noise
- In The Process Of A 5spd Swap...
- Aem Intake
- Exhaust Question
- Tranny/clutch And Brake Questions
- Were Does It Hookup To?
- Exhaust Setup Question
- Plx R-500 Wideband
- Starting Issues
- Dual Radiator Fan Operation With Stock Fans - Electrical Question
- Light Problems
- For Those Who Relocated Their Battery
- Weird Vibration
- Clear Corner Problem
- Importshark Short Shifter
- Dude... Wtf... Flame Tip Exhaust? Haha
- Car Troubles
- 80 Mm Throttle Body?
- Installed Alarm = Cel Po0444 + Po344... Wtf?
- Found This While Searching Through Old Forumns...
- Formulas And Conversions
- Rd1s Power At Wheels
- Ugh Still Having Problems
- Need Silencer Or Glasspack
- Dumb Question, But Answer Please
- Tib Stalled Now Wont Start
- Turn Signal Lights Come On When Braking...
- Who Is Interested In Custom Vacuum Manifolds?
- Power Steering Pump Install Problems..
- Wideband 02
- Stuck Throttle
- Where To Get Gauges?
- Budget Power
- Easy Short Shifter Question
- Taillight Problem
- Need Silicone Coupler Supplier
- Car Alarm
- My Exhaust System
- Scraping Noise In Wheel Well/strut Tower
- 1st Gear Problems
- Buying New Muffler...
- Rad Fans For A '00 Saab 95
- 02 Sensor Position
- Minor Electrical Problems Now Becoming Major Problems
- Another Gk Drag Car..
