Thottle Body Question?
Old Mar 15, 2007 | 05:40 PM
xtremeskier's Avatar
http://www.kspec.com/list.php?ac_id=81&ai_id=1054
Would this not work on a 99' Tiburon. I tried searching but couldn't really find anything. Wouldn't it be the same throttle body...Elantra<--->Tiburon???
When you click on the one for the Tiburon http://www.kspec.com/list.php?ac_id=79&ai_id=616 it says 1996-2001 Tiburon
*2003 Tiburon 2.0L 4 cyl.
1996-2003 Elantra*
These seem like the same throttle body...no?
Old Mar 15, 2007 | 06:04 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Go to sfr instead. They will have what you need.
Old Mar 15, 2007 | 06:19 PM
I know, i was just wondering cuz i like the nozzles for the coolant lines. Thanks though. fing02.gif
Old Mar 15, 2007 | 08:30 PM
Teflon's Avatar
<div class='quotetop'>QUOTE (tanc @ Mar 15 2007, 08:04 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Go to sfr instead. They will have what you need.</div>
They are just a beta 2 with the hole drilled out. I have the same one. You can see where they drilled it
SFR BBTB
Old Mar 15, 2007 | 09:26 PM
tanc's Avatar
No, they arn't just beta 2 tbs with the hole drilled out.
Available sizes are 58, 60, and 65. You can't bore a TB out more than 58mm
Xtermeskier, why do you want to keep your coolant lines? Your just heating up the air before it goes in the TB. Are you concerned about freezing temps? Search it and you'll see -20 and people dont use the coolant lines.
Old Mar 15, 2007 | 09:52 PM
Teflon's Avatar
I was just saying it was a beta 2 BBTB. i didn't mean a stock one. I would go with the SFR though
