Wire Harness
Old Jan 19, 2007 | 11:47 PM
lilo shark's Avatar
i thought about it and was wondering if it would be possible to make a wire harness from the beta1 to beta ecu. since the beta2 ecu has the reflash, etc. in prespective of the honda obd2a to odb1 conversion, etc.
Old Jan 20, 2007 | 12:10 AM
wiwring harness is the easy part.
betaIIs are MAP.
all the assembly code has to be rewritten.
Old Jan 20, 2007 | 01:07 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
yes it can be done... virtually all of the sensors are the same (well, except the map sensor) but essentially have the ecu flashed with the maf stuff in it instead of map
yes, the gk's did go back to the maf setup, so all the info will be available
ask mad_john or bluetree to get you a qoute for a beta2 harness from korea
Old Jan 20, 2007 | 05:20 AM
xxxmonoxidechild's Avatar
also remember the beta2's dont have the iac valve
