- CEL p0121, p0506
- is this true? (a/r graph)
- Rside shifter
- My battery light in the dash doesn´t show.......
- short shifter
- Exhaust questions..
- LEDs or Incandescent, Which is brighter?
- I think I have a lemon.. TONS of problems!
- my little CEL problem
- Alternator?!
- HID Kit
- whats the part called
- Exhaust
- AEM Intake
- clutch questions
- Emissions leak
- Another AC Problem
- A little Help about SAFC2
- Short Shifter
- air fuel gauge hookup
- Making my Tib go
- petition to get tiburons turbocharged stock
- 4-1 Header Gasket
- Horse power gain and overal
- AirRam and RSide Install Pics ***NO 56K!!***
- Squeeling Power Steering Belt
- crank pulley help....
- Airram Guys, Hold up! Hondata Heatshield Gakets AVAILABLE!!
- Cruise Control Won't Work? FIX FINALLY FOUND!
- Air conditioning problem
- How Much would you...
- CEL just came on *cont.*
- Air Conditioner Problem
- blower fan..
- recent developments...
- all about oil ...
- IM Install & Dyno
- AirRam IM
- Exhaust tip?
- CEL just came on...
- Sparco Seats
- Gas Mileage
- Return Spring
- What is the best Cat Back system to buy??
- oil catch tank??
- Regular oil change
- RSide Adjustable BBTB
- 1st gen front on 2nd gen
- What do you think about this "+20hp M-modchip"
- Funky ass problem
- Exhaust Question
- CAI sucked up water and stalled engine...
- SAFC II ?
- B & M Short shifter
- 2003 Tiburon
- OBX short shifter rubbing agains boot?
- Bad Batt. or Alt???
- Gas Octane/Brand
- New Engine
- mla's or hla's ?
- Seat Brackets
- Window air leak
- mods to get into 15s?
- Strut Bar/Engine Conflict
- Power Steering Belt squeeks?
- Purchasing specific Tires n Rims
- Headers?
- Revision A Canister Removal/Relocation?
- Cat-Back Question
- Choosing cat back exhuast
- Help: Choosing AirFilters
- CEL - Possible Clogged Cat?
- CEL code 0422
- Intake For 1.8L Tiburon?
- water-pump question
- N/A Max HP
- do you have a tornato and is it worth it
- Exhuast question
- Reverse stalls car, CEL now
- Which Headers are better
- Short shifter problem
- Mileage and Problems for the Tib
- Low end torque upgrades?
- SAFC Gains
- SAFCII Question
- ebay perf. parts?
- Engine Sqeak :(
- Scraping into second
- S-AFC numbers!???!!
- MSD DIS-2... other options???
- ECT + OD
- *Edit 6/7- Help!* OBX 4-2-1 & Fitment issues?
- Good and Cheap Modification
- Phantom Grip Limited Slip LSD
- filter/cai?
- Damn .... this ones got me
- f***** wheel bearings
- Pulleys & cam sprockets
- Hyundai Class Action Suit READ EVERYONE!!!!!!
- Exhaust
- New muffler pictures
- resonator removal -- need quick help!
- sparkplugs.com
- Going custom cat back i think...
- Is my Tibby dead? ... UPDATE: No it's not! :)
- A couple of general questions
- OBX catback exhaust
- tranny problems
- let's get these betas straight..
- misfire?
- 99 tib i4 perf. parts?
- Threw CEL... possibly CAT?
- Temp guage overheat
- Shifting chirp
- Current progress with the CryO2 install.
- Underdrive Pulley
- Electrical Problems
- Headers
- RD2 Stock MPG
- electrical help
- Stock performance specs
- K&N replacement for AEM filter
- Gonna get some BRISK plugs
- Why do cars ALWAYS have many things go wrong all at once
- what type of cat back system should i get?
- MAF/S-AFC Voltage...
- problems pumping gas
- What do you guys think about the twin loop muffler
- aluminum or steel heads on a 01 tibby
- CAI for 2000
- Getting Sponsored
- Woo Hoo!! My first trophy!!!
- a question for all those Tib Experts
- more of a question
- ecu
- 2000's tibs(turbo)what kind?
- Just got a blue top.
- Exhaust Question (muffler swap and resonator addition)
- Missing a piece for my CAI?
- How much for 60k Service??
- Vibration Noise? (Split)
- Tiburon Header and Cat Converter Complete Set
- MBRP V6 exhaust
- WANTED Dyno - Tiburon V6 Headers
- Motor Mount
- GK 4cyl. Intake???
- Picture of my Beta II w/mods
- High performance clutch
- painting strut bar and spark plug cover
- Boring of SR BBTB?
- arospeed headers
- Apex'i S-AFC for 2001 Tib?
- 97-01 Hyundai Tiburon 4 Cyl Cold Air Intake
- Does no one make a complete cat-back anymore for the 2000-2001 US Tib?!
- What to do with 2003 4cyl Tibby?
- whats the highest hp beta NA
- Dyno runs of Port and Poilsh Head TIBURON!
- Between 1.6 Beta and 1.8/2.0 Beta
- Dyno Results for Stock V6 auto Tib
- beta engine?
- Perma Cool Oil cooler BOLT ON Kits for Tiburons (Onario,California residents)
- Some differences between RD (Beta1) and XD (Beta2) heads.
- Hyundai TSB 2003 Tiburon V6 ECM Reprogramming For Engine Hesitation
- Bolt on cats for the 2k1 Tib
- K&N wants u 2 prototype a tiburon intake
- What is wrong with my car's setup?
- Beta Head Removal
- Complete AU ECU Pin for Tiburon 97'?
- Sourcing a BETA 1 motor
- More info on "weak" V6's...
- Beta II injector size?
- Beta1 motor for sale. 30 day warranty
- high performance chips for tibby?
- Dual Exhaust on 2001 Tib.
- Beta II w/SAFC
- Tiburon Throttle Body mod
- CVVT Beta II
- beta I or beta II
- 2.0 beta info
- 2.0L Beta dyno results from NOPI......
- 03' Tiburon Engine Mods...
- 1.8l beta engine rebuild
- 2001 tiburon
- Tibby Engine
- Electronic Cruise for your tibby?
- will rx-7 fuel pump work in the tib?
- 1/4 time 1.8 beta?
- RPW 2K1 tiburon cams
- Go Eclipse?
- 2001 Tib cams on sale?
- Turbulence Beta
- If/when the CVVT Beta comes out
- Dyno woes from my Tib
- HP of Beta Engine
- Tiburon primary/secondary coil quest.
- 03 Pedal Covers will fit the 01' Tiburons
- Cold Air Intakes for my tibby
- AEM cai for A-Rev Tibbies..
- HKS exhaust for Tiburon, need opinions
- question for diambo (eclipse throttle body on tiburon?)
- gt cam
- 2003 Tiburon V6 Exhaust
- who is the fastest tiburon here?
- 2004 Tiburon Engine
- 2001 Tibby catback?
- motor mount inserts for 2001 tibby?
- 2003 V6 Tiburon Exhaust decision.......
- Beta Cams (non OEM)
- HP increase for 2.0 Tib
- 4-into-1 headers question
- Uregent!! Please post wiring diagram for s-afc for 2nd gen tiburon
- Don't give up, we still looking for a Delta intake manifol.
- Special Request: Picture of throttle cables from 2K-2K1 Tiburon
- MSD sci ignition box on 98 tib?
- 1997 1.8 Tib TQ vs. 2001 2.0 Tib TQ
- just realized something bout the map'd beta's , i think lol
- Zex for 2.7L Delta engine?
- cut muffler of of 2k1 tibby
- where are the 2001 intakes???????????????
- Any info on the Theta engine? or CVVT Beta?
- does anyone make a BIM for a tibby
- Autolite Tibby wires
- tib throttle body
- when is header coming for 03 gt v6 tib?
- Do BETA engines consume oil?
- Refresh/Update on Delta V6 F/I problems
- where is the ignition coil on 01 tib
- Tibby filters
- Injen CAI for 03 Tib Dyno results.
- OBX short shifter
- n/a BETA max hp #'s
- Random which cam is best for the tib?
- Twin Engine Tiburon
- Boring out the beta
- 6 speed for 2001Tiburon?
- Custom exaughst, does this soudn good?
- Injen CAI for '03 Tib
- strait exaught on tibby?
- Exhaust cam part numbers
- HOW DO YOU U PUT DUAL EXHAUST ON A TIB
- Dif. between exhaust manifolds for 1.8 and 2.0 Betas
- 2nd Gen Tibby's
- What are my chances??? - Please help
- What size is the stock exhaust pipe for a 00 Tiburon??
- SPEED CHANNEL TIBURON
- 97 Tibby Custom CAI
- tib go faster
- Shark Racing Tiburon Cams
- Comparison between Beta1 and Beta2 Intake manifold and head ports.
- TIB vs Tuscani exhaust question
