CEL code 0422
Old Jun 12, 2004 | 07:20 PM
Talux's Avatar
Went and had my car checked at autozone. The guy said that I had code p0422, catalytic converter bank 1 sensor low. What causes this and how can I fix it? I got this problem about a week after I got my exhaust installed. To install the new exhaust the guy gutted my manifold cat and put a magnaflow cat downstream of that under the car before the resonator. This didn't happen until a week after I got the exhaust. Any ideas on how to fix this? Thanks tons in advance.
Old Jun 12, 2004 | 08:07 PM
same thing happened to me. It'll probably go away. It was after I installed CAI... happened about 1 week later.
check it out
http://www.rdtiburon.com/index.php?name=PN...iewtopic&t=1674
Old Jun 12, 2004 | 09:29 PM
drafter's Avatar
Why did he gut your manifold cat? There was no reason and that is illegal to do. Did he re-locate any of your O2 sensors? If he did not, that is the reason your CEL is on, because the second O2 sensor is reading the same as your first. The second O2 sensor needs to be placed behind the new cat.
HMA p0442 DTC page
Old Jun 13, 2004 | 05:39 AM
Voiddweller's Avatar
<div class='quotetop'>QUOTE (drafter)</div><div class='quotemain'>Why did he gut your manifold cat? There was no reason and that is illegal to do. Did he re-locate any of your O2 sensors? If he did not, that is the reason your CEL is on, because the second O2 sensor is reading the same as your first. The second O2 sensor needs to be placed behind the new cat.
HMA p0442 DTC page</div>
YUP
