tranny problems
could be a "kick down servo switch",
check out this site, www.hmaservice.com/webtech , alot of good info there
yea your tranny is starting to give out
if you have the warranty by every means use it...
BTW.. ill buy that speedo sensor off of it
animal3767@aol.com
he should be able to reuse his old one...
animal3767@aol.com
i also have a problem with it heztaing if it is parked all night. it's like i put the gas down and it sputters and it wants to stall but doesn't if i hold the gas down i can smell gas . injecters maybe? but once it warms up it's fine same with the tranny if the o d is off.
I would let it warm up for a minute or two before driving off... maybe just rev it while it's in park to get gas moving through... don't just turn the key on and drive off. It only happens when it's been sitting for a long period of time, right?
