Obx Pulleys
Old 04-08-2010, 12:18 AM
Bommello's Avatar
Alright so branching off from the WDYMTW thread.
Who has had problems with their OBX pulleys? I know I'm getting a squeal and so are DTN and 01Steve. But who else has had problems, what were you're solutions (if any)?
Old 04-08-2010, 02:50 AM
Regit's Avatar
Vehicle: 2000 tib
no squeels here,I went back to stock crank pulley last night,Just makes me feel safer.. The obx just didnt appear beefy enough,plus the stock has harmonic balancer in her..
Old 04-08-2010, 11:04 AM
Bommello's Avatar
Did you only have the crank pulley?
Old 04-08-2010, 11:32 AM
I only have the obx power steering pully. It squeels, then I have to tighten it, and eventually replace the belt about 20-30,000 miles. I'm going to go back to stock. I think the problem is that it's a full V instead of the standard U shape that comes on the tiburon.
Old 04-08-2010, 11:51 AM
alice6's Avatar
i have the "power pulley" set as well and mine is always squeeling (not always a loud squeel but i can still hear the belts over the engine). its only the power steering belt though, and it could be because mine didn't really fit when i got them. i'm considering upgrading to a full ark set.
Old 04-08-2010, 03:08 PM
Bommello's Avatar
Yea it's the PS that squeals. A couple times I had the WP squeal and the car would start to over heat but it hasn't happened for a while.
I hate starting up my car now because of this.... it's embarrassing lol.
Old 04-08-2010, 03:16 PM
Cary a 14mm socket, 3" extension, a breaker bar, and a can of belt dressing. That's just standard stuff for me (except the belt dressing). I have a 113 piece toolkit and a toolbox full of stuff along with an entire car care kit in my trunk at all times.
I never bothered to do anything about th eobx pulley because it's quite easy to fix. Just a 14mm wrench to tighten and an additonal 12mm wrench to replace the belt.
Old 04-08-2010, 07:26 PM
alice6's Avatar
i'v never noticed any problems with the water pump pulley. the power steering pulley i got was a smooth bore, and the power steering shaft on my car was splined. i just sort of pressed it on with the lock nut so it's not quite in line with the pulley on the water pump, i always figured that was the problem.
+1 on the belt dressing though, i spray a bit on every once in a while to quiet her down a bit. i tighten the belt every oil change as well, not a big deal really.
Old 04-08-2010, 07:28 PM
i have the obx crank pulley, power pulley set, and timing gear... no problems at all. shrug.gif
Old 04-08-2010, 07:45 PM
Bommello's Avatar
I guess quality control at OBX is quite lax lol.
