Wiring Up Oil Pressure And Boost Guage Lighting
Old Apr 17, 2006 | 05:44 PM
supercow's Avatar
ok I'm hooking up my guages and was wondering if anyone had already figured out the wiring to the dimmer switch. I'm going to keep looking for an answer and put it up here if I find out.
my gut on it though is that the + from the guage goes to the green/white and the the - goes to the green/black and the other black wire on the switch is for ground.
Old Apr 17, 2006 | 05:46 PM
'treezy's Avatar
EDIT
_________
you realize your boost gauge is only going to get power when the corner/headlights are on...
Old Apr 17, 2006 | 06:22 PM
supercow's Avatar
it's mechanical, this is just for lighting.
Old Apr 17, 2006 | 06:25 PM
'treezy's Avatar
search for "gauges" or "LED turn signals" something along those lines and my member name. tibby01 pointed out to me which was pos. and neg.
webtech hasn't worked for me in a while either, but you can find out there too (assuming the diagram is actually readable). Some of those are insane.. can't zoom in.
Old Apr 17, 2006 | 06:37 PM
supercow's Avatar
I'll look for that thread your talking about.
edit: i only came up with two threads and neither were it..
found this one, didn't find the info i needed though.... http://www.rdtiburon.com/index.php?showtopic=9504&hl=
Old Apr 17, 2006 | 06:50 PM
zoned019's Avatar
Vehicle: 97 Tib
If you're looking for a solid +12v when the parking lights are on, then your l33t diagram is correct.
Old Apr 17, 2006 | 06:51 PM
supercow's Avatar
sweeeeeeeeeeeeeeeeeeeeet, thanks alot zoned!!!!
Old Apr 17, 2006 | 09:33 PM
*cough*multimeter*clears throat*
Old Apr 17, 2006 | 09:58 PM
Jay-M's Avatar
Vehicle: 01 Tiburon
yes, it is very handy... it should be a standard part of a toolbox
Old Apr 17, 2006 | 10:01 PM
really. i learned that hard way from wiring my uber alarm that korean colors in the etm manuals are different than american colors...lol
gotta go by pin numbers and then doublecheck everything with a DMM.
