Brake Light Stays On
Old Apr 23, 2006 | 03:00 PM
Screwdriver's Avatar
Seriously, I'm shocked by the number of problems that keep springing up one after the other.
Just 10 days after I got my CEL fixed, my front left Caliper changed and now my Brake light is on.
I checked the parking brake and it is fully down. The light disappears only for a few seconds when the Tib accelerates from stop or brakes to a stop. Otherwise, always on.
Lately it just stays on. Has anyone seen this before?
Old Apr 23, 2006 | 03:07 PM
no, but the switch is right underneath the center console. easy to check.
Old Apr 23, 2006 | 03:14 PM
tanc's Avatar
Vehicle: 1997 Tiburon
^^ Check the switch and check the connections. You might be grounding out somewhere.
How I would go about doing this is parking near a wall, garage door or in the garage so you can see the light from the brake lamp. Now pull up and down on your ebrake slowly and see if at any time the light flickers or goes off or anything. If nothing, I'd pull the center console out and check connections. Wiggle wires around while looking at the wall for light. If you haven't found the problem this way, I'd check webtech for the wiring diagram and trace it out to pinpoint your problem.
EDIT.
OH it's your guage cluster light. OKAY. I'd go through the same steps but instead of being infront of a wall. If you can't find your problem i'd also take off the dash and have a look at the wires there.
Old Apr 23, 2006 | 03:39 PM
mb1604's Avatar
also check your brake fluid level. my e brake light went on when my fluid was low. at the begining hte light would go on and off becuase as the car moved the level would move and trip the sensor
Old Apr 23, 2006 | 04:23 PM
yes, that is the other thing that brake light does. As yours goes out when accelerating, I am going to bet that you are way low on brake fluid.. especially if you replaced a caliper and did not top off the resevouir
Old Apr 23, 2006 | 04:34 PM
tanc's Avatar
Interesting, I never knew we had that option.
Old Apr 23, 2006 | 04:43 PM
Incorrect. I did top off the brake fluid when the lines were bled.
I'll double check to be safe. It would seem to be the only thing that makes sense.
Old Apr 23, 2006 | 06:46 PM
Tiburonmoo's Avatar
Vehicle: 2000 Tiburon
My mom's Taurus does the exact same thing. We were told it was a problem with the master cylinder from Firestone. We haven't had it repaired yet because the car sits in the garage majority of the time. It didn't make much sense to me but I'm not that well versed mechanically either.
Old Apr 23, 2006 | 08:39 PM
Yup... one of those nice "safety features" that all cars in the US have had since the late sixties or so. At least new cars let you know when you are low on fluid. My fiat only lets you know when one circut (front or rear) does not have the same line pressure as the other. In other words, you have to hit the brake to find out you have a problem with the brakes. Probably the worst time to find out.
Also.. I edited the title. I have a petpeeve about the misuse of similar sounding words. It is a BRAKE, not a BREAK.
Old Apr 23, 2006 | 09:43 PM
Think about it man, you just had a caliper replaced and you have a light for the brakes...
