Coolant Overflow Tank Temps
Old Apr 19, 2006 | 02:27 PM
tibbytib's Avatar
Just as the topic states, I need to know how hot you think the overflow tank gets. You will all see why, hopefully by tonight. Need opinions ASAP. Thanks!!!
Old Apr 19, 2006 | 06:15 PM
off hand I would say it can get up to around 250 degrees if you overheat your car.
Old Apr 19, 2006 | 07:00 PM
no hotter then boiling water. that is overtemp.
i'd say 160-190 operating temp.
Old Apr 19, 2006 | 07:11 PM
radiator fluid is only half water. the boiling point is much higher.
the answer to your question depends though. are you overheating? if so, that tank is getting a bunch of freshly heated coolant, and will be hot as hell. if you are just driving and everything is normal, i dont even think anything enters or leaves the overflow tank.
Old Apr 19, 2006 | 10:16 PM
tibbytib's Avatar
Thanks for the responses. No problems overheating, just wanted to know the temp range. I am chroming my coolant overflow tank and powersteering tank and needed to know the operating temp ranges. I decided to base coat it with a ceramic engine paint that good to 500 degree's so all should be well!. I'll post pics when I get more done. Thanks!
