Power Windows Not Working ?
I've checked all of the fuses, I've glanced at the wiring, unplugged the battery, unplugged the switch and plugged it back in a gazillion times... HELP I just got it back from the body shop so it had to be something they did, but I can't get it back there till monday... HELP PLEASEEE
I dont know if it also works for the driver side but have you checked the Window Lock? Sometimes I've locked the windows without noticing and get all freaked out, then realize its that damn switch.
KustomizedTiburon: You need to fill out your profile information.... FULLY! What year tiburon do you have dude?
I'd put my money on the pink fusable link C in the engine bay.
What kind of body work was done?
You could check to see if the window motors are plugged in, or quite possibly the window relay. The pink fuseable link as DTN said is one of those block fuses that's about a 1/2" cube. Check all that and report back.
Okay, I checked the relay thing under the hood, it's fine, I even switched two of them to see if it was busted and didn't look like it, but of course it did nothing.
The wires seemed all connected although I'm not very familiar with our window systems inside the door, they shaved the handles so they very well could have disconnected the motor, but it looked plugged up to me. THIS IS WHY I NEVER TAKE MY CAR TO A SHOP!
Ok well theyre fixed now, when we were hooking up the solenoids and running the wire through it pulled one of my extended wires loose but it was under the wire loom and electrical tape on my doors so it wasn't visible... owned.gif
