Car Wont Start.
Old Oct 26, 2007 | 06:42 AM
2000 elantra's Avatar
I checked the fuel pump and it was not pumping so I went and replaced the pump and it still wont start.The pump is pumping so wtf can be causeing this.I put oem plugs in when I did the pump so what could be wrong?any help would be great.
Old Oct 26, 2007 | 08:19 AM
Try turning it some more. Check the gap on the plugs. Check for spark. Check the injectors.
Is it a fast turning like it's never going to start, or a slow turning, like it's trying to start and isnt?
Old Oct 26, 2007 | 09:54 AM
How do you know your fuel pump wasn't pumping?
What is the last thing you did to your car?
Have you checked your Crank Position Sensor?
Did you do the bypass DIY test to test your old fuel pump before you took it out?
See, if the crank position sensor is broken, or loose, it won't get the signal to fire off the fuel pump. Doing the bypass test tells you that your fuel pump is working for sure, 100%. If that works, check your CPS
