1.8 Ecu Installed
i just got my 1.8 ecu today and it was installed in a total of 1.5 hours from the time i recieved it. the plug was a PITA but its in and i will post more on how it feels later i am going on a 3 hr drive today to go to the penn state football game for the weekend. ill post more when i get back
^^huh?
It works man. And I'll tell you why. The 1.8lECU advances the spark timing a little, which gives you more power. It also means you need less fuel to run the same HP levels, so you save fuel. Its a win win.
Yeah, that was pretty stupid HKC, I've been telling you folks about this for years, of course it works. We have dozens of members with it installed.
ok im back from my road trip and i noticed a few things.
first of all i hace the ecu from the 98 elantra the good one.
i can say that it does feel smoother through the rpms, no dead spots at all.
second it defenitily has a speed limiter/fuel cutoff at 110 mph.,,has anyone else had this, did you do anything about it.
and last since my rpms were aroung 4000 the whole time it is hard to judge the gas millage but i got 31.25 mpg that up from 28mpg the 2 pervious times i made the same trip with the 2.0 ecu.
see i've got a Revision A Tiburon so that mixes up the equation a little. let's say i put a 1.8 elantra ECU in right, then there's a problem because my evap is different on my car than the elantra. most likely it will not function.
i'm afraid of this mod. see if i had a 2000 tiburon it would easy, no cannister, no problems, FX name dropped and tiburon comes standard with everything fully equipped and just swap. but it's a darn 97 so i've got a bunch of issues to think about.
anyone try this with Rev A?
