misfire
Old Oct 9, 2011 | 03:12 PM
vampyric's Avatar
Vehicle: 2012 genesis coupe gg
Default misfire
I have a misfire in cylinders 1,3, and 5. Any idea what to check out that would cause this. The tib has 84500 miles
Old Oct 9, 2011 | 03:23 PM
nos4atu's Avatar
Bad plugs or worn wires. Usually the issue when I get a misfire.
Old Oct 9, 2011 | 08:41 PM
All the cylinders on one bank say either something funky in the ignition system or else you had Jiffy Lube "replace" the wires last time you had the wires replaced.
Old Oct 10, 2011 | 08:27 AM
ChattTownShark's Avatar
Vehicle: 2001 tibby
Double check the plus wiring they could be out of order
Old Feb 18, 2012 | 03:17 AM
psin2005's Avatar
Vehicle: 2001 Tiburon 2.0L
I've had the engine misfire twice, and both times it was easily fixed by changing the spark plugs and the cables upgraded to racing cables.
Use NGK plugs (10 bux for 4 @ advance auto) and pickup spark plug wireset from rockauto for around 40ish. and you'll be good to go (hopefully)
If this doesnt fix it, you have bigger problems but lets not think about that till you try the basic things.
I know a lot of people dont agree with this but I like to change the oil after doing plugs as well (unless you VERY recently did an oil change). ~20 bucks (local auto store deal).
Old Feb 18, 2012 | 03:40 PM
krazytib's Avatar
Also check your ignition coils due to your mileage.
Old Feb 20, 2012 | 09:29 AM
dckeith18's Avatar
Could be your throttle positioning sensor
