Misfiring
Vehicle: '03 Tib GT
Misfiring
So the other day I went to the store for some things, the drive there was fine but when I was done I got back in the car and the engine was really rough. My brother was with me and we both agreed it sounded like it was misfiring. So I looked at me plug wires and saw one that had gotten pinched, so I changed plugs and wires since it was about time anyways. It ran great for about 35 miles then it did the same thing while I was driving. I then changed the coil pack. 40 miles later, here we are again. Am I missing somthing?
When running rough it sounds like its puttering but it doesn't shut down. The tone of the engine/exhaust gets much deeper, like a STI Impreza with an aftermarket exhaust on it. Other than that it seems to run fine, I crippled it home and nothing changed.
Vehicle: 2005 Hyundai Tiburon GT
They just looked like normal wear? They weren't white like an indication of a vacuum leak? Is you have tried the spark and its good try fuel and vacuum leaks. Misfires can b anything from faulty fuel components, vacuum leaks, faulty emissions, low or uneven compression ect....
Vehicle: '03 Tib GT
So I managed to get it up to autozone for a scan. It came up as injector in cylinders 1 fault. I have the code written down somewhere.....I'll get it later. Anyway I was wondering the best way to handle this, cleaning(and how to) or just replace it.
Use (only) Internet Explorer
Go to https://www.hyundaitechinfo.com/
Sign up for a free account
Navigate to:
DTC > TIBURON(RC) >1999 > G 2.0 DOHC > Engine > Engine Control > DTC - P0201, P0202, P0203, P0204 (FUEL INJECTOR) > Diagnostic Procedure
also
TSB > Engine Electrical System > 99-36-014 Misfire Code Diagnosis
P0201 = Injector-Cylinder No. 1
P0301 = Misfire at cylinder 1 detected
This site contains The Manuals, including shop and electrical, and more, direct from Hyundai.
Navigate to:
also
