Reducing Belt Noise?
Old Apr 20, 2009 | 08:52 PM
I replaced my belts recently. My power steering belt is noisy. I spray it down with belt dressing and the noise goes away for about 1 hour, then it comes right back. Any suggestions?
Old Apr 20, 2009 | 10:36 PM
UrS0NvS's Avatar
http://www.rdtiburon.com/index.php?showtopic=31006
roflmmfao....you even posted in this thread not even a week ago Adam, dayum!
Old Apr 21, 2009 | 04:24 AM
A squeeling belt is different from a noisy belt. A squeeling belt is caused by the rubber getting hard or the tension getting loose. I have a noisy belt. Squeeling can be cured by spraying with belt dressing.
It makes a kind of a shhhhh sound until I spray it with belt dressing. Then the noise comes back
I've repaced the belt and it still does it.
Old Apr 21, 2009 | 06:36 AM
likeyoumeanit's Avatar
What kind of belt are you using? It might just be the nature of the beast, Im running a dayco polycog and have no issues.
If you're looking for a a permanent fix you could probably glue some LED's to a midget and put him under the hood to continuously spray dressing like an air freshener.
Old Apr 21, 2009 | 06:38 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
Mine would squeal and make noise like you say (esp in the winter), until i got a different brand (goodyear gatorback, from autozone)
Belt dressing never helped me with anything, the noise would come back in at most a day
Old Apr 21, 2009 | 08:07 AM
I think Goodyear makes some belts designed to be quiet-running. I got one for my power steering, it had grooves across the width on the back. It ran quiet till it started to squeal, so it's off.
Old Apr 21, 2009 | 03:30 PM
I'm using the dayco polycog too! It sounds like what you'd expect from a bad bearing or something, but as soon as I spray belt dressing on the belt, it just goes away!
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/Mk-VsmGNdSs"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Mk-VsmGNdSs" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
This puzzles me.
Old Apr 21, 2009 | 04:11 PM
dude, I dont think you got the camera close enough to the pulley there, you need like another 2 inches closes nana.gif
Thats odd, idk, mine doesn't make noise
Old May 10, 2009 | 07:14 AM
radu_rd2's Avatar
Me thinks it's not the belt, it's the bearings..
I have a similar but much worse squeak when it's cold. I tried spraying brake cleaner on the inside of the pulleys and on the belt, and the squeak kinda went away for a few seconds then came back right away. I tried spraying wd40 near the PS shaft (through the pulley, around the center), and the squeak was completely gone. So it's the bearings and I expect it will come back soon, time for a new pump..
I suspect that when you spray that belt dressing (or when I sprayed the cleaner), a small amount of liquied gets around on PS shaft and quiets the bearings for a while.
Old May 10, 2009 | 07:29 AM
No sir. It was the belt. I replaced the crappy Dayco Polycog belt, which I purchased upon a good recommendation from another user, and the sound went away. When you spray a belt with belt dressing and the sound goes away, it's the belt. The Dayco Polycog belt is too thin and sits down inside the groove too far. I went to the dealership and purchased a stocker and it sounded great afterwards. It was the belt.
