Motor Mount?
when i'm at a stop i can feel the motor shaking from the brake pedal and when i'm braking into a turn. i'm thinking it's the motor mounts any suggestions?
K-spec i beleive sells just the poly bushings but get ready to play russian roulette with your money. you might get the part, you may not.
there are several DIY's all over the web that shows in depth detail on how you make your own poly mount.
