Cold Air Intake Question
I think the bypass is a load of bs. I mean I live in Florida and I havent had any problems.
As long as you clean and inspect it regularly you should be fine.
just dont go mudding or anyhting, then you might need one.
I have run into TWO times where my CAI sucked up too much water and my engine died. I had to dry out the filter, MAF, and TB hose and let it sit for 15-25 minutes in a downpour on the side of the road before it would start up again.
I also have the Veilside front bumper, and the top of the intake has an air inlet. You can see how the intake sits right behind the vent in the bumper. I put the Bypass valve back on and have never had a problem with the valve installed.
The two times it happened, it was raining hard, roads had plenty of water, but I didn't drive through any standing water and stayed on main roads or the interstate. The engine died, and felt like it was gasping for it's last breath before drowning... jerked a few times and stopped as I let off the gas, but within seconds it crapped out.
Some say they lose a few HP using the bypass valve, but if it's going to save my engine, I'll use it. I'm sure I'm losing some power, and I can tell a difference in the tone of the CAI when it's on vs. when it's off (suction and exhaust).
it just depends on where you are and how particular you really are. being that since a CAI doesnt add much in terms of HP, adding the bypass valve just depends on you.
Vehicle: 2011 Kawasaki ZX6R
It doesn't add much HP but for the price it's hard to beat. As long as you watch when it's raining and avoid puddles as best you can you will be fine without a bypass. You have to drive slower in the rain anyways, misewell keep an eye out for deeper water.
I drove through water half way up my door with the cai and... no it wasn't fine, I hydro-locked my engine lol. 2 out of 4 cylinders full of water. I did not willingly drive into the water.. it's a long story. I can tell you how to fix the water in the engine problem if it ever happens to you and it doesn't bend a rod though
I say don't bother with the bypass... it negates any gains you would get by putting another filter where water wont get in it. Problem is the air is hot where the water wont reach and it will just heat the air your CAI brings in.....
Long post short - If you are going to drive through 3 feet of water then get the by-pass valve. If not then just keep an eye open in the rain
My CAI was the 3rd modification I made to my car. I've been running it for almost 3 1/2 years now. It is great and I have never hydrolocked my engine. That VeilSide kit with the big open area in the front directing water into the filter might cause problems. I've driven through snow and rain, sleet, ice, cross country, through (I never measured) 8" puddles. I've never had an issue. I just slow down and take puddles so as not to splash water too much. I think the CAI on a stock bumper with a fog light blank is a great option.
I run a standard AEM dryflow air filter. Here's a picture with the bumper off. Note the AEM has a flat face instead of a 2nd cone
here is a picture of the fog light blanks. This is the wrong side, but you cannot see my air filter from either side
<a href="http://i236.photobucket.com/albums/ff111/DrivingTibNaked/100_3609-1.jpg" target="_blank">
</a>
</a>
