Help Weird Idle Problem And Weird Stuff In The Crankcase
The idle prolem: When the clutch is pressed in or it is in neutral the idle is at around 950 rpm's but it drops to like 200 then shoots back up. It does this over and over but not all the time. Its becoming more frequent. Sometimes the rpm's will go so low it stalls.
Stuff in the crankcase:I switched from Quaker synthetic to penzoil platnum synthetic just for one oil change just trying out diffrent oils and i noticed there is a weird substance on the inside of the oil cap the best way to describe it is it looks like mustard. Is this a problem?
Any help would be great thanks
Don't want to be a jerk but it's been covered before..... many times...
Answer:
http://www.rdtiburon.com/index.php?act=Search
Answer:
