Switch Wiring Options
Old Apr 1, 2009 | 02:40 PM
fury's Avatar
I'm wondering what's the difference (if any) in connecting a load (e.g. a light) to a switch by connecting the ground at the switch or the power at the switch. In other words, there are two options: the switch can act as a a connector to join the load's grounds, or its power. Is there a difference? And what's recommended, when? I see different people connecting it in different ways, but I can't find an explanation.
Old Apr 1, 2009 | 02:49 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
No electrical difference, you can choose either depending which is more convenient in terms of setting up the wiring and such
Old Apr 1, 2009 | 02:59 PM
fury's Avatar
So that's the short of it, radu: no difference smile.gif Thanks, dude! Makes me feel better. I was really curious.
Old Apr 1, 2009 | 03:02 PM
radu_rd2's Avatar
If you expect that any shorts are likely to occur, there is a slight difference.. For example, with the switch at ground, the rest of the circuit will be at +12V so if a wire to metal ground short occurs, the fuse will blow even without turning the thing on. Still unimportant, that's about it haha
Old Apr 1, 2009 | 04:08 PM
fury's Avatar
Old Apr 1, 2009 | 04:38 PM
tanc's Avatar
Vehicle: 1997 Tiburon
12v system is closed. You'll have 12 volts through out the whole circuit. I believe there is a small difference in amperage as well. Maybe DTN can confirm.
