View Poll Results: What would you do?
Install the full harness and move over the smt6 harness - 3-4 hour install
70.59%
Just replace the damaged parts. - 1 hour max
29.41%
Voters: 17. You may not vote on this poll
New Wiring Harness - Vote!
Old May 13, 2009 | 10:52 PM
supercow's Avatar
What to do?
I'm installing a new wiring harness I'm planning on installing it full then the insurance guy recommended splicing the harness in place of the burnt wires. Injectors, coolant sensors, etc.
So what would you do if it was your car?
Old May 14, 2009 | 06:58 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
If you can solder on the car I see no problem with splicing.. Changing the whole harness sounds like a real hard job
Old May 14, 2009 | 07:19 AM
supercow's Avatar
hum...I have no problem soldering. I do it all the time, plus I'd shrink wrap and then cover with wire loom.
Old May 14, 2009 | 07:45 AM
Done properly, a repair can be as reliable as the original. You might even get in a little bit of wire tucking action while you did it.
If you don't know what done properly means, however wink1.gif then I say go with the whole harness.
Old May 14, 2009 | 07:48 AM
supercow's Avatar
lol, part of what I do for a living is run cable.
Old May 14, 2009 | 10:34 AM
frozen's Avatar
Vehicle: 2001 Tiburon
I'd stick with a repair job. I'm sure replacing the harness is a huge PITA. What I would do is go to the junkyard, chop up a wiring harness and replace the sections that are damaged rather than splicing alot. This way you'll have a completely new injector harness spliced in with the old feeding wires at one location, rather than having 50 splices all over the place.
Old May 14, 2009 | 11:10 AM
Personally I would replace the whole thing if Insurance gave you money for one from the dealer. Otherwise splicing would be fine. Just make sure the wires are not burnt at all where you splice.
Old May 14, 2009 | 11:43 AM
supercow's Avatar
I've got a junkyard one from tib_500 that I was planning on putting in full. It's a big job.
My plan would of course be to cut well behind the burnt sections solder in the new wires, shrink wrap, tape, wire loom, zip tie.
Old May 15, 2009 | 04:53 PM
stealth's Avatar
Vehicle: 2000/Hyundai/Tiburon
If you have the harness I would replace the whole thing. You don't know if some of the wire got fried up underneath the non-burnt insulation. You could have alot of wires fried that don't show on the outside. Just my .02.
Old May 15, 2009 | 06:53 PM
frozen's Avatar
Insulation has a lower melting point than copper. If the insulation is in good condition, the copper did not burn through.
Kinks and bends are a completely different matter though.
