Return To Non Return Swap
Old Mar 28, 2009 | 09:39 PM
My buddy has a Mitsu Eclipse fuel rail and fuel pressure regulator to get rid of. The port spacing is the same, it's a 2.0 engine with slightly higher compression meaning it burns more gas so therefore would probly flow better.
I'm wondering what would happen if I replaced my Hyundai return style fuel rail with a Mitsubishi non-return style fuel rail then just plugged up the return line. Any ideas?
Old Mar 28, 2009 | 10:11 PM
no, no, and no....
no point in swapping the fuel rails...
no point in even attempting to run a non-return type system.
to put it in simple terms.. return system > returnless system in every way..
and the stock beta rail can flow more hp than probably any beta that exists in the US today.
Old Mar 29, 2009 | 12:08 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Dude, do some fluid flow calculations, I doubt your car has even more than 200whp, and thats with "boost".
Our stock rails can easily support 300whp. I think you got a lot more upgrading to do before you reach the rail as a bottle neck.
Old Mar 29, 2009 | 03:00 AM
Ok, just wondering. He's trying to get rid of it and I personally think it looks better then my stocker. If it would be a downgrade then hells to da naw.
I'd estimate 225 ish crank HP with nitrous.
What is the downgrade in a non-return style fuel system?
Socks, did you mean 4 cyl engine instead of beta?
Old Mar 29, 2009 | 07:13 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
he means that the stock beta rail can flow enough fuel to feed even the most powerful beta engines around
btw i don't think higher compression means more fuel is going in, just that more power is extracted from the same mixture
Old Mar 29, 2009 | 07:18 AM
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
400whp>end of discussion
Old Mar 29, 2009 | 12:37 PM
^^Wow. You've got a whole bunch of HP!!!
Back to the origonal question
<div class='quotetop'>QUOTE (DTN @ Mar 29 2009, 12:39 AM) <{POST_SNAPBACK}></div><div class='quotemain'>I'm wondering what would happen if I replaced my Hyundai return style fuel rail with a Mitsubishi non-return style fuel rail then just plugged up the return line. Any ideas?</div>
This is not an extreme mod. This takes about 30 minutes and a foot of fuel hose. Parts are free.
Old Mar 29, 2009 | 12:40 PM
back to my answer..
your right, its not an extreme mod, its a stupid mod. its a DOWNGRADE
Old Mar 29, 2009 | 12:51 PM
Dude, seriously, can you give a reason? instead of saying, it's a downgrade, explain why it is a downgrade?
The only thing I've found on the internet is to keep aircraft fuel from boiling and vapor-locking at high altitudes.
With parts being free, this return line deletion would be akin to a spoiler or resonator deletion.
Why would it be a downgrade?
Old Mar 29, 2009 | 12:56 PM
search more on the internet, you will find the answer.
parts being free, to downgrade is still stupid..
if someone gave me a free high end carb, i wouldn't go from EFI to CARB......
the only point of this 'downgrade mod' is so you could put it on your list of mods like your video ipod. i guarantee if you did and anyone who knew anything about fuel systems saw it, they would laugh at you.
