Exhaust Cam
Old Apr 28, 2005 | 08:23 PM
emstib1's Avatar
Ok, I looked on kspec.com and all I saw were intake cams and exhaust cam sprocket. Does anyone know where I can get an exhaust cam? I searched on here but couldnt really find anything (FYI, i suck at searching)
Old Apr 28, 2005 | 08:35 PM
hamhead's Avatar
You really don't need an exhaust cam unless your running extremely high lift/duration cams (ex. 272s)... if your just running a 1.8L cam, or smaller cams like 254s, then the stock one will be fine.
Old Apr 28, 2005 | 08:44 PM
CyberShark's Avatar
You won't find an exhaust cam by itself anywhere. the only single cams available are the intake cams (1.8 and XD)
Old Apr 28, 2005 | 08:48 PM
I believe the only other exhaust cam out there is for the Beta2.. and it is smaller than ours for less power.
Old Apr 28, 2005 | 09:09 PM
hamhead's Avatar
KSpec I'm sure will be able to get 264 degree paired cams, or higher... if you want to go that route. However, they will cost ya a good amount of cash.
Old Apr 28, 2005 | 09:23 PM
CyberShark's Avatar
I already contacted Kspec about that some time ago. They can get a set of cams but the car will have to be tuned to them (SAFCII or similar piggyback will be needed).
